I have owned a Dish Network ViP612 for a few months now and I have been through THREE boxes from Dish and NONE of them have worked properly from the first day I got each of them.
Problems with EVERY box I have received:
1. Picture freezes or jumps for a second or so periodically. Happens from one to four times per hour. Sound cuts out during skip. About half the time, if I go back 10 seconds, it will play that skipped bit properly. The other half of the time it will skip again at the same place.
2. Box freezes up for up to a minute. Won't accept any commands and picture is frozen and sound stops. After waiting up to minute, it works again. Seems to happen primarily when I hit pause or rewind the first time during any TV watching session. Happens about every other time I watch TV.
Note that I have an antenna to access local HD channels with the Over the Air (OTA) tuner in the DVR. Reading in another blog it seems many have had these same problems with the 612 and I wonder if its related to those using the OTA tuner? I'm also using an HDMI connection to the TV and an optical connection to my home theater receiver.
What's the configuration of others having the problem?
Has anyone that has had these problems been able to solve them? What's the solution?
Rob
Rob
