AVS › AVS Forum › Blu-ray & HD DVD › HDTV Software Media Discussion › XBMC Issues (if you use it come inside)
post #1 of 5
XBMC (Home Theater PC Front End)
I've noticed that when I play my MKV files (5.1 source audio) in something like VLC or Mediaplayer Classic I get the full 5.1, however through XBMC sends a dolby surround (2.0 psuedo surround) via the analog and not the true 5.1 signal. Any ideas why?
In other words (hard to explain)...all 6 speakers are playing audio but the rear channels aren't getting a discrete audio signal but rather a sampling of the front two.
Windows XP Pro SP3
Auzen Xi-Fi via analog outputs
Everything off in the control panel
Thoughts?
post #2 of 5
Originally Posted by Nosferatu View Post
Thoughts?
I would post your question in the HTPC forum here.
post #3 of 5
There is a setting to use Dolby digital or pro logic. Set it to digital.
post #4 of 5
but I"m using analog outputs (6 RCA cables)
post #5 of 5
Your audio drivers should do the job of decoding the dolby digital and outputing it via your 6 rca connection.
  Back to Forum: HDTV Software Media Discussion
