Do I need to set this up as two separate 'devices' with HDMI assigned to one device and Component/Toslink assigned to the other device?
correct, this is the best way to do it. If you assign them to the same "name" then the HDMI will always take priority.
It's helpful to not think of input names as being rigidly stuck to one device. For example, I use my Blu-ray player to play CD's, but my settings for music are not the same as for movies (plus it's a pain when you use CD audio over HDMI because turning the display on/off cuts the audio). So I hook up the BDP with HDMI (for movies) and optical (for CD's) and assign them to different names, one is called "BLU-RAY" and the other is called "CD" and I have different tweaks (e.g. Dynamic EQ offset) for each one.
channel HT and want to use the 3310 to power a play room and a gym. Is this possible? I seem to be getting only 5 channels in the HT??
every speaker mfgr wants you to think their speakers are SOO good than only a fancy expensive amp can do them justice. The 250W rating of the speaker is just an indication of MAX power handling capacity.
