Thanks to both of you luckdog and batpig - so are you suggesting that I do i/p scaling off for HDMI and leave it on just for SD/analog sources ?
No.
Scaling already IS off! Unless you have changed the default settings. And, even if you did, the point we are making is that the scaling WILL NOT cause the symptoms you are describing. All scaling means is changing the resolution, e.g. taking a 480 signal (480 x 720 pixels) and blowing it up to 1080 (1080 x 1920).
There should be NO CHANGE in color, brightness, sharpness, etc., regardless of whether you have the scaler on or off.
Trust me, I have swapped through the past four generations of Denons with HDMI switching -- AVR 2307, 888, 789, now 2310 -- and the HDMI picture quality is IDENTICAL with all models.
Something else is up here. Try swapping in the old receiver and/or try connecting the components directly to the HDMI inputs on the TV. Does the picture look normal? does it change?
