Originally Posted by sterlingma1
My network connection appears to have become disabled. It can no longer get a network connection. Just to be clear on this. I was getting the firmware updates and have used the internet radio. But I just noticed today that I'm not even getting the light to come on on the active port on my router. I have changed cables and have tried other ports. Other network activity works through both the cable and the port it was in. (as evidence I am connecting my laptop to those same now).
I did a complete reset and that did not work. My "Network Information" menu is indicating DHCP On. But no IP or MAC information is showing. Also, under the Network Connecting choice - no additional choices are making themselves available. In other words, everything related to Network is inactive.
I think the last firmware update was a few days ago, and I don't recall noticing the problem right after that. But that may have been the last time, I would have noticed.
I have just check all my other networked devices, and they are all working properly.
Michael
Michael
Just out of curiousity- did you happen to do anything that may have caused your ethernet cable to become disconnected on either end? I have actually done this before by accident when resetting my router.
If this is not the issue, have you tried power cycling your modem down? Unplug it for a minute or two, then reconnected and reset your router.
(Not sure if you have done this or not- certainly worth a try)
