AVS › AVS Forum › Audio › Receivers, Amps, and Processors › ** OFFICIAL ** Denon AVR-3310CI/990 Owner's Thread
** OFFICIAL ** Denon AVR-3310CI/990 Owner's Thread - Page 131
post #3901 of 3903
Originally Posted by jdsmoothie View Post
As the 3310CI is only HDMI 1.3, the TV can be connected to the AVR with an optical cable to pass the Netflix audio to the AVR.
Originally Posted by batpig View Post
It's no different than any other external source. Assign the input to the name you want to use and off you go.
Thanks guys, that did the trick.
post #3902 of 3903
JDSmoothie,
Authorized dealer for Denon, Marantz, Yamaha, Onkyo, Klipsch, Def Tech, etc.
“** Think the AVR is defective? Reset the microprocessor a few times.”
Just wanted to say Thank you for the above line in your ID byline.
I got a Denon AVR-3310ci used on Ebay. It was listed as is untested and was at $60 plus $20 shipping so on a lark, I thought I’d bid $65 just to see how long my bid would last. To my surprise, I ended up with it for $62 plus $20 shipping. Well, when I got it, it would turn on and stay on but no sound. I went into setup and tried channel level and got sound from the FL speaker and could adjust the volume for that channel, when I switched to the center channel I still got sound coming from the FL speaker and so on for all channels. I saw your reset comment and decided to try it waiting for 4 flashes before removing pressure on the 2 buttons but without success. I figured I had just purchased an expensive boat anchor. I noticed “….a few times” so I tried it again but again without success. I decided I had nothing to lose so I tried reset again this time holding the 2 buttons for 10 flashes and it worked! I have tested the 7 channels and GUI and tested a blu-ray with excellent results.
Again, Thank you for the suggestion. Next time I think I will be a little more cautious tossing a bid on Ebay though.
post #3903 of 3903
