Originally Posted by graphicguy
Sounds like the pre-amp is turning off when you hear the click. That's also the reason there is no hum.
Could be a a ground loop hum. If it's bugging you, you can start the process of unplugging different sources and see if you can isolate the ground loop hum.
If it's not giving out a low level hum when it shuts down, I wouldn't worry about it too much....especially since it's not noticeable from your seating position.
Someone said that the new amp comes with a ferrite bead clamp. That's something that's usually used to alleviate hum. When you reinstalled the amp on the MFW, did you wrap the connections with electrical tape?
As I previously stated I did not have a hum issue with the original amp. So not being an EE I would assume I wouldn't have a ground loop issue with the replacement amp as nothing what so ever has changed in my HT system. And I have installed the cheater plug that is supposed to eliminate ground loop issues.
I did rewrap the two large wire connections with electrical tape so they are the way I found them when I opened the sub up. I routed those two wires to the left and the grey wire to the right for non ground loop issues as recommended in the AV!@# forum for good measure while I was in there. And I did install the ferrite bead clamp per the included instructions.
I have emailed AV!@# tech support with my problem but as they are not open until Monday I thought I would try here to see if any one else has the same problem and what they may have tried to correct it.
Don't get me wrong I love having my sub back in action. I had forgotten how great it sounds to have deep loud bass. But I do want to have a subwoofer without the hum.
