AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › The Official Pioneer 9G North American KRP-500M / KRP-600M Owner's Discussion Pt. II
The Official Pioneer 9G North American KRP-500M / KRP-600M Owner's Discussion Pt. II - Page 73
post #2161 of 6727
Originally Posted by WestTenn View Post
Quick question from an av noob. I know it is not recommended to use powered speakers with this panel without a leveler. I am still considering purchasing the 500m, but can I simply plug in my Polk m30's to the back of this set? Will it drive these speakers?
Thanks for your help.
WT
I am using two Energy Take 5 satellites connected to the KRP-500M audio output for the R/L stereo speakers. The 500M built in amplifier has plenty of power to run these speakers at reasonable volume levels. I also connected the Energy S10.3 powered subwoofer using hi-level inputs from the R/L satellites. Although I do not have the surround sound effects, the stereo sound with deep bass response (down to 20 Hz) from this setup is simply awesome!
The Polk M30 is physically a larger speaker than the Energy Take 5 sats (5.25" vs. 3" mid speaker; 1" vs. 0.75" tweeter) and will probably need a bit more power to drive these speaker elements compared to the Take 5s. I would recommend that you try the Polk M30s with the 500M to see if they give you the volume levels that you desire. BTW the 500M ships with R/L speaker cables (about 4-5' long) to connect your own speakers.
post #2162 of 6727
As counterintuitive as it may seem, larger speakers are often more efficient than smaller ones and require less power to reach the same output. But your advice is sound. He should give the Polks a try, just being sure to be careful with the volume. If there is any signs of distortion in the sound, turn the volume down and don't go above that point again.
post #2163 of 6727
I'm relocating from Europe to the USA in about 2 months time. I've just parted with my 8th gen 60" panel and I'm pondering attempting to buy a 9th gen model when we arrive in the US.
Are these generally still available? When I visited a "local" Best Buy, I was told that the Pio panels should be available through to the end of the year, but I am just wondering if that is really the case?
Many thanks
post #2164 of 6727
Originally Posted by elite-home View Post
There are 2 factors at play here that will significantly derail your assertions, 1. Optometrists have verified that eye site is not as "accurate" as you portray or contend them to be "out of the box", or else we would have no need for enhancement techniques designed to provide better adjustment to our vision which tend to be done with instruments, meters and the like- somewhat similar to calibration, right? 2. There is no such thing as a true, or real videophile as you contend- this is simply another chiding degradation to other forum members who respectfully decline your self-anointed status as the grand pooh bah of Kuroistic display technology. Again, you are allowed your opinion and you can ASS-U-ME to be the be all end all of non-calibrated panel dwellers but this forum is designed for those who prefer the best possible product display their systems can provide and unfortunately you must admit that calibration provides this solution far better than the options you have contended are superior in comparison.
There's a third factor at work here as well: it's called "megalomania." You can toss all the science in the world out there and/or ask him to be respectful of others' opinions and observations, and it won't make one bit of difference: there is simply no way to have a logical conversation with someone so bedazzled by his own perceived brilliance and so contemptuous of everyone else's perceived inferiority.
post #2165 of 6727
Originally Posted by ocZZZZ View Post
Anyone know how to hard set dot by dot on an input on the 500m? if I set it, it defaults back to full after the TV is turned off.
The only way I have found is to turn off the Auto Side Mask detection mode in the Screen menu.
This setting appears to be global and is not saved separately for the presets
or input signal modes.
I have my HD cable box on Input 5 running 1080i and everything else 1080P coming from my Denon 3808 on Input 6. If I change the detect mode on Input 5, it also affects Input 6. It would be nice to have the detect mode only on for Input 5 (or 1080i). Then Dot by Dot would stay on Input 6. But it doesn't.
Does anyone know if there's anyone left at Pioneer that can (or would) fix the 3 remaining "bugs" in the M's? 1) The "global" side-mask function as above, 2) The "voltage" problem that causes clipping with DRE off and 3) The Auto input mode that won't detect RGB 16-235.
Even at the "bargain" prices we paid for these panels, they weren't cheap and it would be nice if Pioneer would fix one or all of them before leaving the Plasma market for good.
--Mark--
post #2166 of 6727
What is strange is that my 5020 with latest firmware did the same thing when I still had it. I could set a mode to dot by dot on HDMI 2 (while watching 1080p or whatever) and it defaults back after the set is turned off. Surprised more people don't see this as an issue
--Mark--
Just make sure you are setting it for each individual incoming source (i.e. 480i/p, 720p and 1080i/p) and once you do so you should not have to keep doing it. It sometimes confuses you because when you toggle channels watching TV you can slip in an out the settings without knowing.
post #2167 of 6727
First let me state I did not have much time watching the 500M before calibration. I got it last Sunday and to have D-Nice be able to calibrate it (I wanted to follow his process as much as possible. You may decide it is not necessary.) I had to get the break-in process going as soon as I mounted it to the wall. I did have some time Saturday night and a good portion of Sunday morning to watch some HD material to get a better idea of what the set could do so I could have some sort of comparison between the pre-calibrated and calibrated TV. I've also lived with the 111 for a good seven months so I'm pretty used to that Pioneer goodness everybody talks about.
Anyway, D-Nice showed up yesterday morning at 10:00 AM sharp and proceeded to get to work on calibrating my 500M monitor. He installed the patch first to open up the ISF Auto, Day, and Night modes. He asked me several questions about the equipment I use and how I like to watch movies etc. At that point I just sat there (pretty much over his shoulder. Hope it wasn't too annoying. I know how it is working while someone is watching ) and asked some questions which he was more than happy to answer. I had Pure and the ISF Night/Day calibrated. D-Nice started with Pure and showed me the report generated and gave me a great lesson on what all those lines and bar graphs mean and then showed me the image before and after. It was great having someone do this and be open to questions and most importantly to explain what's happening. Anyway, I was easily able to see the difference and quite happy but what I was really looking forward to was the ISF modes and what they could do. Well after some time and hearing D-Nice under his breath saying perfect as he looked at his results it was time to check out a sample on Bluray and holy cow was the picture awesome! We checked out a clip from Sin City in ISF Night and the depth and pop (yeah I know) was just amazing. It was like a veil was lifted off the TV. Now don't get me wrong, the unit out of the box is excellent but the calibrated ISF modes take it up several notches that shouldn't be missed by anyone owning a Pioneer. And for anyone who wants to know I migrated to the ISF modes pretty quickly after watching the calibrated Pure mode. I think you'll do the same if you get this done.
So to wrap up I feel like I have new TV (I know I do but you know what I mean) and I'm very happy that I had this done. It's kind of like taking your car to the speed shop and having a chip installed and then having a tech tweak the air/fuel mixture to perfection to squeeze out every last drop of power. If D-Nice ever starts working on cars I'll be calling him for that too.
post #2168 of 6727
Originally Posted by Zues View Post
Waiting for the review. Also was the black level of the 500m really night and day vs 111fd like some have claimed?
As far as black levels go there is a difference. The funny thing is that I see it more when I watch using my bias lights. With the 111 if I were to shut the TV off in a completely dark room with the TV showing only black after the credits roll it was quite clear the TV was on. With the 500M it is much less noticeable. In a room with any kind of ambient light I think it's a dead even race. I'm still going to test it out to get a better idea of the differences. I can't wait for that day when black is truly black. I read in an HT magazine or somewhere recently about the magic feeling you may get when a scene goes black and it's truly black and the room goes dark. I think it's a great point.
post #2169 of 6727
It's hard to say. In the case of Best Buy I don't know if they move that sort of inventory from store to store so you'd be at the mercy of your local Magnolia. It seems clear general inventory is diminishing but if you're willing to work at it you might get a 60". Of course as far as I know BB doesn't carry the KRP line so you'd be looking at a 6020, 151 or 141 rather than a 600.
In this specific case BB may plan to clearance remaining stock because they're getting old, they're not that popular and carrying discontinued brands doesn't fit their retail strategy.
post #2170 of 6727
Thanks for your Report!
post #2171 of 6727
Originally Posted by master92087 View Post
3rd Has burn-in been an issue for people?
I've got the same question as this guy, except change out burn-in for IR. I've read through a lot of the thread, but I wanted to ask the question myself. I am currently looking at purchasing a KRP-500M online.
I'm mostly going to be using the set for games and movies, which is one of the reasons I'm a little concerned about IR. I currently own a 720p Panasonic plasma from a couple of years back. I never really followed any break-in procedures, but I also never really experienced bad IR either.
After reading a lot of reviews here, I recently purchased a Samsung B860 plasma. I performed the full break-in and then settled down to watch a 2 hour blu-ray movie, with widescreen black bars. After the movie was over, I switched to HD cable and the IR from the bars was just horrible. Not only that, but it took close to 20 minutes for it to go away. It has already been returned to the store. I'm assuming that the 500M wouldn't be anywhere near this bad, but it would be nice to hear some feedback from some actual owners.
My second question relates to side viewing angles. After the Samsung B860, I purchased one of the new LG LED tv's, model 47LH90. The picture on this tv is great, but as soon as you move even a little off center the blacks wash out horribly.
I'm pretty sure plasmas in general, not to mention the 500M, don't have this problem, but I figured it was worth mentioning. Thanks in advance for any help you guys can give me. I should have just went with the Pioneer in the first place.
post #2172 of 6727
Originally Posted by jdbimmer View Post
... This is true for all AV modes except ISF Auto/Day/Night ...
Oh the , I die.
There are officially too many things to keep track of -- someone needs to write a Missing Manual.
post #2173 of 6727
I haven't noticed it on the 500M but I've only had it for a short amount of time. D-Nice did mention that it might show IR a bit more than the 111 (which I've never seen) but it shouldn't be a deal stopper. Again I haven't noticed it at all.
Off axis viewing is not an issue.
post #2174 of 6727
I don't rely on equipment. All i know is my 151 like many other first batches of 151's are +green out the box, and it's incredibly simple to raise the reds on the them, drop green a bit, and have a perfectly calibrated picture.
Don't you think that using the term "perfectly" might just be a wee bit of an exaggeration? How about ". . . have a picture that I find completely satisfactory."?
I also calibrate to very sensitve grayscale content in movies which makes it very simple. I'm good enough to take sport mode and make it literally as accurate as pure mode.
You like to toss around absolutes, don't you?
Some would probably prefer it to pure mode. All i can tell you is after evaluating every mode and countless comparisons between all the modes there is no way i'm going to believe some extra isf modes is going to be better than all the modes i already have to work with.
You could have saved yourself a lot of time by typing "I can tweak the existing modes to what I like so don't feel any need to add the ISF modes". Nobody would, or should, argue with that. Your other arguments don't hold up quite so well.
post #2175 of 6727
I owned a 2009 Samsung 58b560 plasma immediately before getting my Pioneer 600M, and I totally agree that the Samsung has some pretty terrible IR. I owned the set for two months, and if I'd play a game of Madden on 360, or if I'd watch a film with black bars on the top and bottom, or if I watched ESPN with the sports ticker on the bottom, I'd ALWAYS get IR and it'd last for about 15 minutes.
I've owned my Kuro for about two weeks now, and I haven't noticed even a single hint of IR. I haven't spotted it a single time, a that's after playing multiple games of madden, watching football on sundays with the score tickers on the screen, and watching about an hour of a movie with black bars on the top and bottom. I've admittedly taken it a bit easy to start with(I'm definitely going to finish up my break-in process before I go all out), but rest assured that you won't have to worry much about IR if you bought a Kuro, especially compared to Samsung's offerings.
post #2176 of 6727
Well they are superior but like i said you have to learn content, and study PQ. Since you paid for calibration on a few panels you would think you would know what a accurate image is by now? But no. You will continue to pay every single time you get a new tv etc. Why? Because you have not learned or will never learn anything in the process. And you will always believe a calibrator, with very accurate equipment superior to the human eye, can do something magically better than you can do. The whole process of watching them with their fancy equipment will make you feel like you can never do it.
And when they leave you think wow, magic.
No, only people who believe that they can get a more accurate picture by eyeballing would say "magic". Those who recognize that, yes, calibration equipment is more accurate than the human eye generally know that numbers don't lie - a proper calibration done with proper equipment will yield a more accurate picture than a "magic" calibration done by eye.
You are confusing preference with accuracy, similar in fashion (and in the tiresome style of debate) to those who defend LPs as "more accurate" than CDs. You can prefer whatever you wish, but the cold hard fact is that you are wrong with respect to accuracy.
post #2177 of 6727
Thanks for your calibration report. I've included it in the flat panel (Post#2) list that's linked at the bottom of my post.
post #2178 of 6727
Thanks a lot cleeve and VidPro. That makes me feel a lot better about my purchase. I'll probably be ordering a 500M either today or tomorrow sometime.
Now for another question: How important is it to buy from a Pioneer authorized dealer? I realize that I won't get the warranty if I buy at an "unauthorized" dealer, but I could easily purchase a square trade 3-year warranty for the difference in the price. I know we can't discuss prices or where to buy, but any general suggestions about what I should do?
post #2179 of 6727
If you can get trusted third-party warranty service without any other warranty then you should be fine.
post #2180 of 6727
Please count me as another happy 'patched' 500M owner.
I've pathed the set last friday after the burn-in ended and applied D-Nice suggested settings, which I've tweaked a little just by eye.
The image has really improved and ISF-Day is exceptional in lighted room situations.
I will calibrate myself the unit in the near future but I really enjoyed it this weekend with several movies (just a little oversaturated red is distracting me).
I'm not sure how to calibrate my tv-cable input though, in Uruguay the cable is a mixup of PAL and NTSC SD channels plus 4 or 5 channels in HD.
The ISF settings are only input dependant, not resolution/TV system dependant so I will have to compromise or manually swicth settings all the time...
post #2181 of 6727
I know how to treat the common cold but sometimes when it doesn't go away I have to go see someone who knows just a little more than I and is willing to diagnose the best solution for me- this doesn't have anything to do with my ability and/or my intelligence in case you wondered. I do not know what the focus is of your postings are but I hope this helped.
post #2182 of 6727
I believe in Square trade's case, you'd be uncovered for the first 60 days or so if you bought their warranty to cover a TV that didn't have a manufacturer's warranty. If you buy the warranty from an unauthorized dealer, they may personally provide the warranty service, but of course they'll charge a premium.
But in general extended warranties are expected to actually extend a pre-existing warranty, so read the fine print.
post #2183 of 6727
From Square Trade's details on their warranties:
We do not cover pre-existing conditions or issues that occur in the first 60 days from item purchase. You should be covered for these issues by the seller, the marketplace (e.g., eBay), and/or the payment provider (e.g., PayPal or a credit card).
If the manufacturer refuses to honor their warranty because they consider your item grey market or not purchased from an authorized retailer, we will still cover you.
post #2184 of 6727
Does the 500M produce a lot of heat for like a bedroom?
post #2185 of 6727
Depends on the room size.
post #2186 of 6727
It was my pleasure. Enjoy your 500M
post #2187 of 6727
It's clear that Zues is proud of not using professionals.
post #2188 of 6727
All plasmas will raise the overall temp in a medium to small room. I have a 58" Panny in a 13x23x9 room, and the room is definitely warmer with the TV on. I also have a 60 inch Kuro sitting in my two car garage running break-in slides, and it is warm in there.
post #2189 of 6727
The AC power here just went out and back on 4 times in a row within 1 minute while my KRP was on (and for added effect, my subwoofers "ka-thump" and smoke detectors "tweet" loudly each time). Then I got the dreaded 2 red Power Down blink code and it wouldn't power up. Unplugged it and all is well...sheeesh! Time to invest in a better power surge protector or UPS!
post #2190 of 6727
Its probably better to invest in a whole house surge protector.
