Originally Posted by jbrady3324
I have a tivo, xbox 360 and a ps3 all hooked up through a receiver. Currently when playing PS3 and Xbox games I have to switch the kuro to rgb (16-235) mode to get the correct black levels. Then when I switch back to the tivo, I have to switch the kuro back to auto mode.
Since all sources are hooked up to the receiver, it makes things a bit complicated. Anyone in a similar situation and has developed a workaround?
I wish you could assign the input mode (auto, ycc, rgb) to a resolution
I'm still learning about all of the settings and what they do, but tonite, when watching Entourage on HBO std definition, I noticed that the credits, which were black, were not very black. The black had a glow to it. Is this the same issue you are describing?
I believe I used the PS3 recommended settings, but think I may be running into the same issue, potentially having to switch settings when watching TV.
Can I harmony remote fix this issue?
Too bad a few vents are blocked off by styrofoam else I'd have started the break in process with the TV still in the box. I did plug it into my comcast HD box today to give it a test run and it looked great! Can't wait to get everything setup.
