Originally Posted by bodosom
Although I can't speak to limited as quoted there are devices that clip (or limit) video level signals to the range 16-235 (or so). These devices won't pass, process or display these out of range signals which are commonly called blacker than black (BTB) or whiter than white* (WTW). A common example in this thread is the KRP which clips BTB and a bit above reference white unless DRE is enabled. Below black is only useful in setting black level (called Brightness on the Kuro) but there's a small bit of above ref. white content in consumer video.
*WTW is more properly know as above reference white since such signals are considered by most to be acceptable in consumer content.
bodosom,
Do you mean that the KRP clips BTB? The 8Gs don't so thats new to me. So there is no way to show below black by increasing brightness on the KRPs?
...I was expecting to clearly see them all.
It has always been said that the differences between the 500M/101FDs and the 111FD are only visable during low APL scenes or a 0% stimuli pattern. Anything else and they will look identical. If you really want to see if there is a difference, put a 0% stimuli pattern on both displays while they are side by side.
