AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › The Official Pioneer 9G North American KRP-500M / KRP-600M Owner's Discussion Pt. II
The Official Pioneer 9G North American KRP-500M / KRP-600M Owner's Discussion Pt. II - Page 204
post #6091 of 6727
No prob with the 320, nor did Doug indicate anything was amiss with the BD signal. I sent Doug a mail notice to review my entire posting here, to clarify anything I may of written. He's likely on the road working.
If I were to switch the current HR21-100 with the same model I have upstairs, the calibrator would need to come back out to correctly adjust the display to the new DVR (?) Every time you introduce a new device within the setup, the calibration result becomes altered, in some or any degree (?)
thanks
post #6092 of 6727
thanks
If you don't have a problem with the 320 going through the 819, then the problem is your hr21..... unless doug forced rgb 0-255 on the 320.
Swapping your box out should not affect your calibration unless Doug calibrated the input specific to the hr21.
post #6093 of 6727
I need some help guys. I would like to get a TV signal to my 600M just in time for the super bowl.
I've taken a look through a few of the posts here dealing with tuners and what not, but I'm still confused. Most people seem to look for a DVR or something to get a signal from some dish or cable service. I just have an antenna in the attic and don't really need to record anything. Is there a specific device (model/manufacture) that can give me a HD signal from OTA channels I get from the antenna? I would like to keep the cost down if possible. Under $100 would be great if possible.
Any information would be great.
post #6094 of 6727
Did you Google the units in the FAQ or check the STB thread?
post #6095 of 6727
Any of the DTV converter boxes (the ones that were free-ish after gov't coupon) would work acceptably well. They'll only output 480i, but that will at least get you a signal.
Otherwise, I would look on Craigslist or eBay for a used HDTV receiver. Samsung made several models, as I recall. That will give you 1080i.
post #6096 of 6727
http://www.frys.com/product/5776692
I used this with an amplified indoor antenna and got every network plus a few others in HD. It works great.
post #6097 of 6727
Thank you guys very much. I think that KWorld SA290 from frys will work for my needs. When I first started reading about them I got confused pretty fast. BTW, do the HD channels over the air broadcast in 1080i or 1080p?
On a slightly off topic note, did D-Nice ever post if he was officially going to be offering calibrations with his new technique/modification that lowers the MLL of the 600M?
post #6098 of 6727
I've owned a 500M for exactly 3 months, and I just now realized how unsatisfactory its' black levels are (it's calibrated properly). Its' blacks aren't even that dark . If this TV has "the best blacks" then damn, talk about fail.
...These blacks suck . If I own the best, then I feel sorry for the rest: because blacks are essential to good PQ. I wish I was still ignorant to what good 'black levels' meant. ...Now I'm just a critic.
These forums are a great, but they're also transform you... Into a eagle-eyed master... Who settles for nothing less than pure-awesomeness: I've acquired that eye, and I'm not happy
post #6099 of 6727
Sounds like something is wrong with your 500M then, I'm not sure how you could be anything but extremely impressed.
post #6100 of 6727
If you look at a totally black image, when in a room with all the lights off you'll see what I mean - just look close, and compare that to the bezel of the TV... It'll make you realize that it's not that dark; nothing like being "OFF." It's just the best plasma can do at this point, which still has lots of room for improvement.
...Needless to say: I'm not impressed anymore.
post #6101 of 6727
Whatever you do, just don't use a PC source and display a totally black pic, in a room with all the lights off. Because it will make you realize that it's not all that dark; like nothing like being "OFF."
I've done all of the above and am quite thrilled every time I do it on any one of my Kuro's....
Sure am glad I'm not as jaded as you are
post #6102 of 6727
Then you might as well give up on TV for the immediate future then, b/c nothing else comes close to the 500M for black levels now. Hell, it doesn't even look like anything is going to match the regular 9g Kuro blacks in 2011.
post #6103 of 6727
You just bought into the hyperbole. Of course it's not off. If you can't see the precharge glow in a dark room you need your eyes checked.
Ah, that's not quite true. Off all the mainstream panels available today the 9G Kuro is two orders of magnitude darker. High density local dimming displays can do better under atypical circumstances but not while you're watching ordinary program material.
post #6104 of 6727
Who calibrated your display?
post #6105 of 6727
...Alright, I exaggerated... The 500M's blacks are pretty dark. And now that I look at actual content and not a black screen, it's not noticeable, and in fact is very dark.
lol, lets move on to another topic. Sry to rustle the leaves
post #6106 of 6727
I have not seen any followup posts. I did see a post explaining how the 500m and 101 panels achieved their lower black level, it stated they were produced in a different/new plant that had more advanced/efficient way to apply coating that resulted in the lower black level.
I don't know if this is associated with the ability for "some" 60" panels to achieve lower black levels. Possible some of these 60" panel were produced in the new facility as well and maybe there is a way to "unlock" this ability? Of course I am only speculating.
D-Nice did state that he was able to achieve the lower black level on his 141 panel with assistance/information from engineer/engineers from Pioneer. He also stated he was looking into the possibility of making this "tweak" available to his customers.
I am also very interested in possibility and hope D-Nice updates us on the progress.
Barry
post #6107 of 6727
Let me guess. You looked at a blank input? Then the black level always will be high(or is it low..confusing..he he)
Maybe someone can explain why a input without source have higher brighness. Is it a voltage thing?
post #6108 of 6727
Barry
+1
This is the first time I've read about this, and boy oh boy would I be all over a D-Nice calibration for my 141FD's if he was able to lower the MLL. That would be absolutely incredible.
post #6109 of 6727
+1
Even if this "tweak" does not work out you will still be happy with D-Nice calibration. He is the best IMO. He calibrated my 600M last spring and I am hoping by the time I am ready for a turn-up he will be offering this service.
barry
post #6110 of 6727
barry
Yeah, from what I've read and my experience here... he's the guy you want to do your Kuro ISF modes.
He offered to do mine when he comes up here in March but I'm still debating and haven't sent him a PM. I'm already in PQ heaven with my self-calibrated (Speers & Munsil) Kuro's so can only imagine how happy I'd be after D-Nice worked his magic! A lower MLL on-top of that would just send me into hysterics I'm afraid
post #6111 of 6727
Pioneer Elite HDTVs are coming back! well... kind of...
http://www.engadget.com/2011/01/27/p...branded-sharp/
post #6112 of 6727
I remember Pioneer releasing LCDs in Europe with panels from Sharp but never read any data or pro reviews of them. An LCD with Kuro processing?
Still an LCD. With an extra yellow pixel. Give me a break.
Actually here is a review of a 2008 Pio LCD model
http://www.trustedreviews.com/tvs/re...37in-LCD-TV/p4
post #6113 of 6727
Please note that the press release is reasonably clear:
Sharp Electronics Corporation, the U.S. subsidiary of Japan’s Sharp Corporation, and Pioneer Electronics (USA) Inc. today announced that Sharp will be granted license of Pioneer’s “Elite” brand for a line of high-end flat panel displays
I don't see the word Kuro. There will be a "Pioneer" Elite television with a matching logo for your Elite BD, receiver and sundry other Pioneer Elite products.
post #6114 of 6727
After reading that review of the 2008 LCD model I would be interested to see these if they have local dimming. Pioneer would not let them use their name lightly.
post #6115 of 6727
Hi Guys,
Is this thread dead or has it moved?
Ron
post #6116 of 6727
Originally Posted by Ronmck View Post
Hi Guys,
Ron
No it's not dead but Kuro displays were discontinued two years ago and at this point most folks that want/wanted one are quite familiar with them. The Elite/non-Elite television threads remain reasonably active. Probably because of the larger trade in used models.
post #6117 of 6727
Thanks, Bodosom. This is kind of sad. I am an owner of a D-nice calibrated 600M. I haven't posted in over a year but I still liked stopping in here to read.
It seemed to me that on 1/28/11, somebody just turned the lights off.
I guess I'll have to get my Kuro fix on the other treads. Thanks again, for responding. BTW - I have always enjoyed your input.
Ron
post #6118 of 6727
Phosphors don't work like on/off switches. You have to apply a current to see anything and with standard operational voltage you get the deep dark blacks. The blank input screen is just designed like a standby so that the screen is ready to respond to input. I don't think Pioneer really cared about designing a set that was phenomenal at displaying a blank input to show off its black levels (like LED fanboys seem to love these days). When you're actually displaying content, the blacks will be darker than anything else out there. Functionally, the panel is in a different state on blank input than with an on-input device pushing image to it.
post #6119 of 6727
You can revive this thread by making a calibration-program for mac:s. Please.. Somebody?
post #6120 of 6727
You can revive this thread by making a calibration-program for macs ...
What would this program do and would you expect it to look?
