Originally Posted by
D-Nice
This will happen with Dot by Dot when setting the Orbiter to Mode 2. It is normal and can bring eliminated by switching the Orbiter to Mode 1.... but you loose the Orbiter function and run a higher risk of IR if you watch a lot of 1080 content that contain undesirable items like logos, tickers, black bars, etc.
Well crap, i forgot about the orbiter. Yes i did have it on mode 2. Put it back on mode 1 and dot by dot does have the full pixel mapping.
Forgive me guys, my mind is filled with other distractions these days.
beagle five
I am a pixelmapping freak, but 9g kuros is the only tv I found actually look better not pixelmapped! The depth seems better.
But pixelmapping do not mean that all pixels are used, the source might have a black line in the edge or other things you should not see.
So thats what you are seeing i think.
Full makes the picture a tad bigger. Maby thats why you feel you get better depth. After using full for so long it's going to take me awhile to use to dot by dot again. Full scales the image only a couple inches, but it's something i notice.
And you're right, even with dot by dot, depending on the program, you still get a small unused portion of the screen.
