AVS › AVS Forum › Industry Area › HDMI Q&A - The One Connector World › How does Ethernet get squeezed into HDMI 1.4 ?
post #1 of 8
Can someone who has read the HDMI 1.4 spec shed some light on this ? (Kurt maybe).
I am guessing that because of the packet nature, it needs a seperate physical connection, and can not be multiplexed into the HDMI bit stream.
I am also guessing they will use the one previously unassigned connector pin and maybe "steal" one of the shield wires to allow ethernet signals.
Hopefully someone can provide a detailed answer
post #2 of 8
They use a big guy with strong arms.
post #3 of 8
post #4 of 8
post #5 of 8
I wrote an article about this, which is posted over at Audioholics:
HDMI 1.4: No News is (Mostly) Good News
The short answer is that they've taken the one unused conductor, twinned it into a twisted pair with the hot plug detect conductor, and put the shield for this pair together with the DDC/CEC ground. This still means only one data pair, rather than the two pair required for a working ethernet connection, so there's a whole messy protocol to handle that and to mix it with the "audio return channel" which 1.4 also added.
I predict that nobody will ever use this feature. But we'll see...
Kurt
Blue Jeans Cable
post #6 of 8
Thanks Kurt,
So it looks be to yet another "kludge" to keep the marketing dept. happy.
I guess only time will tell if the ethernet over hdmi ever takes off, or if HDMI 2.0 with a new improved 24 pin connector will save the day
post #7 of 8
Kurt
Given that there are two broad categories of HDMI 1.4 cable (setting aside connector types and speed ratings) and that running the extra wire will typically add a few pennies to the manufacturing costs do you think sellers will bother to stock both HEAC and non Ethernet flavors ?
It seems to me that a 1.4 HEAC (HDMi Ethernet Channel + Audio Return Channel) cable will be work with anything you through at, whereas a 1.3, 1.2, 1.4 cable without Ethernet will obviously not work with the "latest, greatest" gear.
So if we assume that a 1m HDMI cable costs maybe $1 at source and a 1m HDMI HEAC cable costs maybe $1.10 wouldn't make sense to only stock the HEAC flavor and save the cost of the inevitable tech support issues ??
post #8 of 8
I think that's probably right. We will probably just switch over to the HEAC-type stock as soon as we can, as the cost difference will be minimal and it saves having a lot of extra items and, as you mention, support issues.
Kurt
Blue Jeans Cable
