| Is the Crown up to the challenge for one or two of these subwoofers? |
Hmmm.....Two of the single driver enclosures or two of the dual driver cabinets?
Here's the specs on the Crown:
Macro-Tech 1200: 310 watts into 8 ohms, 480 watts into 4 ohms, 675 watts into 2 ohms. Output Power in Bridge-Mono Mode: 1,300 watts into 4 ohms.
The answer is yes, the Crown will perform nicely. It is only roughly half of a K2, but never the less will provide extremely good performance. I ran a pair of single HE 15 cabs with an Ashly FET 2000M, which has very close numbers to your Crown, and they sounded great!
| Will my mortar crack, and cause the first floor to join me in the basement? There is rumored to be over a mile of steel in the floor/ceiling, between the top and bottom layers. |
I can't speak for the structural integrity of
your basement, but
my basement home theater has fared just fine. I wouldn't leave a lot of breakable items on shelves, though
http://www.avsforum.com/ubb/smile.gif
| Performance wise, what type of comparison to the EV's be? |
I have a lot of experience with EV Pro Line drivers from my days in the band, and they are much more efficient than the HE 15's, but they give up the last bottom octave. Good HT subs need to have a response that digs down into that last octave, and that is one area that the HE 15 really shines. Most any sub can go down to 40 hz (the EV's included), but the range from 40 to 20 hz (or even lower) is the biggest challenge for a subwoofer to overcome. The HE 15's are very much at home down there
http://www.avsforum.com/ubb/biggrin.gif
| I currently have a ancient Lexicon CP-1 processor, and would probably use it to generate the sub output. I don't recall what it's capabilities are, but enough? |
That model is beyond my days, so I can't comment. That would be a good question for Buzz, though.
| There has been talk about the active driver having two connections? Does each driver require a stereo amp? |
No. This topic has been covered elsewhere in this thread, so you might want to reread the entire thread (if you have a couple of days
http://www.avsforum.com/ubb/smile.gif ).
| How would these speaker designs compare to products from Decware? |
Dunno...I've never heard of Decware...sorry.
| Is Marchand doing a custom 3 channel XM9 for your front 3 as Mark Seaton mentioned they might in the other thread? |
I am only in the
planning stages on that part of the project, but I will probably be going with the Marchand XM9. If they won't customize it for me, I feel pretty confident that I can do it myself with the help of a few friends. I want to finish the Focal/Morel MTM's first
| What did you end up doing for your center configuration? I'd ask about this in the other thread, but it seems everyone moved over here. |
The thread is not dead....It's just on hiatus for a few more days. I'll be posting more info over there soon.
| Anyone have the number for a reasonably priced Crown Amp dealer? |
You should talk to Ken Lopata about that. I think he found the best price around ($1250 for a K2?). I bought mine used, but they are few and far between.
STOP DVI/HDCP/5C/DFAST!
