Originally Posted by
hifiaudio2
A prominent theater designer has recommended Triad in ceiling Bronze LCRs to mate with my front three cat 12s. You might want to check those out.
supercop
Hi hifiaudio2
One of the member ( Art ) who has Cats LCR and TRiad set up told me that the triad is the weak link in his system.
hifiaudio2
Well that doesnt sound good. I will ask Art about it. Thanks.
Art has the little bronze surrounds from probably 8+ years ago. The Bronze surrounds are very different than the LCRs. The InCeiling speakers are much more capable, but a pair of sealed 5.25" woofers shouldn't be expected to keep up with a Catalyst 12C. Fortunately when surrounds are much closer to the listener they don't need to be quite as powerful. If they are 1/2 distance of the main speakers you can save 3-6dB in required output for the same level at the listening area. The InCeiling Bronze LCRs are a plenty reasonable application choice when appropriate. The Triad Gold surrounds are significantly more capable.
As some mentioned, the Klipsch THX Ultra2 series have some fairly capable surrounds, even if the specs are a bit ambitious on the efficiency. The larger
Personally I prefer direct radiating/very wide dispersion surrounds over dipole surrounds unless you are right on top of the surrounds or back against the wall, but that certainly doesn't mean they can't result in good sound.
JTR has the S8-HT/LP & Slant-8 which are also good choices for passive surrounds which are available and much more capable than more traditional hi-fi options.
As I have confirmed a few times on my own forum, we will be expanding the Catalyst family to include 2 surface mounted speakers this year, but don't expect to see too much info on those until they are a few weeks from delivery.
