Originally Posted by Matt Sullivan
Ive found exactly why they sound better in films its not the equipment or anything there's nothing wrong with your cd player between NTSC and Pal well Pal as you might know plays 4or 5% faster so in theory if you took your favourite music and made it faster by about 5% ( i use final cut pro quickly and export as WAV) then you should find the favourite tracks you've heard in your favourite movies sound just as good on you iPod/iTunes or what ever player you like trust me 5% or maybe 10% not too much unless you want your tracks to be all chipmunk singles trust me 5% will soup up tracks swimmingly. I've done it just now with Doubleback ZZtop which is played at the end of Back to the Future Part 3 i was like that sounds better so i 5% it today job done
Is this a joke?
It's 4% by the way, and it's almost 1 semitone. I wouldn't even know where to start if I were to answer this.
The reason some songs "supposedly" sound "better" in movies is that they most likely REMASTER the original tracks/songs. The difference is most noticeable with older material, obviously.
