I am starting to decide what to upgrade my audio system with in conjunction with going with a larger 2.35 acoustically transparent screen and was referred to Wayne's web site.
The more I read, the more I am intrigued. Any first hand impressions of these speakers? Specifically the Pi-4 which is a two way with a 15 inch woofer and compression driver and horn.
Looking to build 3 for the L/R/C/ and would use his kit.
If your system doesn't sneak up and startle you every so often, it's probably compressing. And that's an understatement.
