After suffering with motion smearing for a couple of years now I finally think I know what type of LCD "blur" I'm having trouble with.
I've been reading about retinal blur due to how a progressive image is smeared across the screen as opposed to a strobed image like that on a CRT.
Can anyone recommend a good LCD that strobes the back light (thus reducing retinal blur) but doesn't use any frame interpolation?
I was looking at Philips' "Clear LCD" solution, but apparently while it does strobe the backlight it has the dreaded video effect that makes films look unnatural.
Is there any way to get the best of both worlds?
I was very close to going for a plasma but I believe the problem is only reduced and then I'd have to contend with phosphor lag.
Any help would be greatly appreciated!
Thank you.
Thank you.
