Hello,
Has anyone used a regular 100baseT hub (not a switch, I know a switch won't work!) as an amplified splitter for video-over-CAT5 baluns?
I've seen a plethora of component-over-cat5 and HDMI-over-cat5 baluns, as well as component- and hdmi-to-multiple-cat5 splitters. Unfortunately, none of these products really work for what I'd like to do.
I'm working with a multi-story house that has CAT5 "Home Run" wiring from every room down to a small wiring closet in the garage. Every room has 2 CAT5 drops. I'd like to preserve one CAT5 drop in each room for networking use.
So, the idea is to use a component-to-CAT5 (or HDMI-to-CAT5) balun at my video source in the living room, send the CAT5 signal down into the wiring closet, then, in the wiring closet, split it into 3 or 4 signals that get sent up to CAT5 drops in the bedrooms, etc.
The problem is, for the life of me, I can't find a video distribution amp that takes an already-converted CAT5 signal as an input - all the distribution amps take "native" component, VGA or HDMI, leaving me with 8 outputs in the living room, where they don't do me any good.
So, if anyone has used a hub to split a video signal, or can recommend either a generic UTP distribution amp, or a system with a component or HDMI sender, UTP splitter, and receivers, that would be fantastic.
