AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Do I need to mess with the Xover on Pioneer VSX-919AH-K
post #1 of 5
I ordered this reciever and should arrive on Tuesday:
http://www.amazon.com/gp/product/B00..._ya_oh_product
My question is, my current Sony recieve is old and kinda crappy, you cannot change the Xover.
I know the Pioneer has that autocalibration microphone, after running that, do I need to manually set the Xover for the speakers? or not?
What is recommended Volume and Xover for the Subowoofer? I have this one:
http://stores.channeladvisor.com/the...0%20Watt%20Sub
post #2 of 5
Turn the volume on the sub to half-way. Set the x-over to max and phase to 0. Run the auto calibration and the receiver will adjust your x-over for you. Assuming your speakers aren't huge with built-in subwoofers....then double check the settings the receiver made and make sure it set all your speakers to 'small' so that it sends all the bass and lfe to your subwoofer.
post #3 of 5
where do u set pahse to 0 ? in reciever?
post #4 of 5
Many subs don't have one. If your's doesn't don't worry about it.
post #5 of 5
ok thanks
