I am currently running a set up with a sony dvd player used as transport (optical connection) to yamaha Rx661 driving a 5.1 channel set up of Definitive technologies Pro800 cinema + jamo subwoofer (150w).
The system lacks bass in a big way and I feel better quality while listening to a philips two in one system which is way less costlier than my set up in question.
What would be the best way to go ?
1. Upgrading to a dedicated cd player with an expensive transport ( I do understand that with the current set up the sony player is just used as a transport and the conversion is done by the DAC in RX661 which is a Burr Brown one). Shouldnt this give me good sound quality ?
2. Go for a studio reference speaker Klipsch reference series ?
3. Try a different room ? Acoustics ? The above set up is in my living room with just three sides closed and with a mirror sliding door background.
4. Set up a system from scratch if none of the above are good and RX661 is just good enough for a HT set up?
Please advice I am confused !!
) that the poster had the configuration (xover, etc.) correct... never hurts to check settings firsst...
