Originally Posted by BB_Mike
Geo, I recreated this last night by taking the component 1 hook up and leaving the cable on connected on the device end. got the same blinking on the HDMI 1 input. The component I had going to my Camcorder, and when I disconnected the camcorder and switch the TV to HDMI I saw the flickering on/off of the screen. I disconnected the loose component cable from the back of the TV and away it went.
It seemed to only happen when I switched from component to HDMI. If I just powered the set on, all was fine. It might be simple link related, not sure. I try not to find problems these days, just fix and avoid them!! life is easier this way.
Thanks for the follow-up. Have you gotten the blinking when powering on using a component input? I was using the Component 1 input because of the sync problem. Anyway, the replacement is supposed to be delivered today. Hopefully, it will have a later build date and have the latest firmware.
So I really dont know if this is something normal or an issue that shoud take care off....
