Does not seem to output dual dvi 12 bit, Donald. Neither does Gefen's DCI scaler.
PremierViewProHD-Digital Cinema
INPUTS
1x HDMI 1.3 with audio, 10-bit capable
1x DVI-D,
1x HD-SDI (SD-SDI compatible)
2x Composite Video via BNC (NTSC/PAL/SECAM)
2x S-Video via MiniDIN (NTSC/PAL/SECAM)
2x Component video YPbPr/YPbPrS/RGB/RGBS HD/ED/SD via BNCs
1x SVGA via 15HDD
2x SPDIF coaxial digital audio via RCA
2x Toslink fiber-optic audio
4x Stereo analog audio pair via 2 RCAs
GENLOCK
Genlock to house sync, component input, HDMI/DVI, SVGA or HDSDI.
(NB DVI cannot be used for genlock if HDMI is displayed and vice-versa.)
OUTPUTS
1x DVI-D, 10-bit HDMI 1.3 capable
1x SVGA via 15HDD
1x SPDIF coaxial digital audio via RCA
1x Toslink fiber-optic audio
1x Stereo analog audio pair via 2 RCAs
DISPLAY MODES Pre-defined automatic output configuration enabled by menu
selection of 320/220/210 or 110 series Sony projector type.
USER CONTROLS
Control/Ports
Front panel controls with character LCD display
4 user configurable presets
Programmable soft keys for faster input switching
Remote control via RS232 serial port
Remote control via TCP/IP
USB port for firmware update
PC control software included
Signal Paths
10-bit ADCs for composite, S-Video
12-bit ADCs for component video
10-bit HDMI, 8-bit DVI support
10-bit HD/SD-SDI
Modes of Operation
(1) Full image processing and filtering, with or without I/O frame rate tracking, or
I/O lock mode.
(2) Low latency mode with reduced processing, per-input or per-input-persignal
selectable.
Power
Integral PSU, 100-240VAC 50/60Hz, power via IEC connector.
Rear-mounted power switch.
Front standby/on control key.
Premium-grade cooling fan for reliable installation in equipment racks
Mounting Information
Extremely rugged, professional 19” (2U) Rack case with carrying handles.
Case colour : Black
Impressive Image Processing features
ü Chroma improvement processing with CCS, CUE, ICP filtering
ü Per-Pixel Motion Adaptive adjustable TNR (temporal/film noise)
filtering - HD & SD
ü Motion Adaptive adjustable CNR (MPEG mosquito and block noise)
filtering - SD
ü 4-field per-pixel motion adaptive de-interlace with MDDF (multidirectional
diagonal filtering) - HD & SD
ü 3:2, 2:2 and non-standard cadence pull-down correction with
automatic adaptation to non-standard and broken cadences.
ü Frame-rate conversion
ü Selectable 24Hz, 48Hz, 50Hz or 59.94Hz 2K/1080p output modes
from 24p or 24sfp input
ü 2D image detail enhancement and sharpness control HD & SD,
realtime unsharp mask
ü Color gain and cut-offs adjustment – HD & SD
ü Gamma selection – HD & SD
ü Aspect ratio conversion – HD & SD
ü Picture in Picture (PiP)
ü Audio delay correction automatically adjusts for video processing
time
ü Per input channel, per signal type parameter storage and automatic
configuration.
ü Uses Silicon Optix Realta with HQV by Teranex video processing
with Calibre’s custom firmware
ü Clean input switching
ü Zoom, pan and tilt function
ü Extreme keystone correction
ü Image flip left-right, up-down
Warranty
3-year return to base warranty covers parts and labour, shipping excluded.
Calibre UK operates a QA programme compliant with ISO9001:2000
Key Features
Inputs Front
Controls
Remote
Control
Processing Motion
Adaptive
Noise
Reduction
Real-time
Unsharp
Mask
Audio
Follow Video
24p
Output
Support
HQView400DC DVI, HDMI,
2xComposite,
1xSVideo,
1xComponent,
1xVGA,
1xHD-SDI
OSD based
with direct
input select
keys
TCP/IP
based
webserver or
TCP/IP &
RS232 based
API
IDT-HQV on
ReonVX video
processor
SD only
PVProHD-DC DVI, HDMI,
2xComposite,
2xSVideo,
2xComponent,
1xVGA,
1xHD-SDI
Front panel
LCD, user
definable
input select
keys with
signal status
indicaton
TCP/IP or
RS232 based
remote
control
application
and API
Realta professional
image processor
running HQV by
Teranex postproduction
grade
real-time
processing using
1Tflop TVP DSP
HD & SD up
to 1080i50/60
and 1080p24
max
HD & SD up
to 1080i50/60
and 1080p24
max
Analog,
digital and
optical audio
support, user
definable
automatic
audio routing
Yes
INPUTS
1x DVI-D,
1x SVGA via 15HDD
GENLOCK
OUTPUTS
1x SVGA via 15HDD
USER CONTROLS
Control/Ports
Signal Paths
10-bit HD/SD-SDI
Modes of Operation
I/O lock mode.
selectable.
Power
Case colour : Black
filtering - HD & SD
filtering - SD
time
configuration.
Warranty
Key Features
Inputs Front
Controls
Remote
Control
Processing Motion
Adaptive
Noise
Reduction
Real-time
Unsharp
Mask
Audio
Follow Video
24p
Output
Support
2xComposite,
1xSVideo,
1xComponent,
1xVGA,
1xHD-SDI
OSD based
with direct
input select
keys
TCP/IP
based
webserver or
TCP/IP &
RS232 based
API
IDT-HQV on
ReonVX video
processor
SD only
2xComposite,
2xSVideo,
2xComponent,
1xVGA,
1xHD-SDI
Front panel
LCD, user
definable
input select
keys with
signal status
indicaton
TCP/IP or
RS232 based
remote
control
application
and API
Realta professional
image processor
running HQV by
grade
real-time
processing using
1Tflop TVP DSP
HD & SD up
to 1080i50/60
and 1080p24
max
HD & SD up
to 1080i50/60
and 1080p24
max
Analog,
digital and
optical audio
support, user
definable
automatic
audio routing
Yes
You seem to be very satisfied with the overall performance now!
