Originally Posted by ddingle
We are setting up our recently installed Titan Reference for 3D. DPI has been here and upgraded this unit to 3D.They tested it with their player. We bought the 3D upgrade for the Lumagen Radiance XS as well. Should be good to go,but it doesnt seem to be working so far? Connecting the Lumagen to Input 8. Using Directv's 3D channels. 3D is turned on in the projector. Lumagen is set to Auto on 3D
Are there still EDID issues with the Titan? Even after the upgrade?
We have a couple more days to get it going.
Couldnt get the BCS game in 3D tonight
I have my Titan Ref 3D connected to a Lumagen XE all works great for Directv and Bluray.
It has to be setup a little weird though. First the Directv has to be connected to Input 3. Input 3 works for the half-res 3D formats. Input 8 is for frame-packed bluray.
I have output 1 on my lumagen going to the AV Receiver and then to input 3 on the Titan. That works for everything except 3D bluray.
Output 2 on the lumagen goes straight to the Input 8 on the Titan
The lumagen has to have 3D mode turned on, auto wont work cause the lumagen doesnt recognize the Titan as an HDMI 1.4 capable display.
The lumagen can vertical stretch for cinescope 3D blu-ray content.
Also ESPN broadcast in 720P sbs on Directv. The Titan has to be put into 3D professional mode because it wont recognize that signal automatically under 3D Consumer mode.
The only thing that wont work well is my PS3 for gaming. The only input that accepts frame-packed signals is input 8, but there is no scaling for input 8. Since ps3 does gaming at 720P frame packed all i get is a small 1280x720 image centered in the 1920 x 1080 chip. SUCKS!!!
Lumagen should hopefully be able to help with this soon. I have spoke to Jim at Lumagen and we will see a way to convert or scale between different 3D formats eventually.
