AVS › AVS Forum › Audio › Speakers › Official JTR speaker thread
Official JTR speaker thread - Page 53
post #1561 of 8249
I did remember that you had the 12's. , but I was thinking they were LF's. I am an engineer and I even went back and checked my speakers again to double check myself.
We are both right. They were originally T12LF's but I upgraded them to the new coax and crossover last fall making them T12HT's .
I am planning an upgrade to the new drivers/crossover soon. It may seem like a PITA to some, but the potential to upgrade is one of the aspects that I really like about the JTR's.
post #1562 of 8249
Originally Posted by orcarola25 View Post
Anyone get tracking numbers on their T12s yet???
I have. UPS is supposed to bring my three T12's tomorrow.
post #1563 of 8249
the T8 mystery is solved
The first 2010 Triple 8's were 12.75" deep but were measuring down to 81hz so I made them a 1/2" deep to get them to 80hz. Not an auditable difference.
got that reply from Jeff earlier.
post #1564 of 8249
The website is current. The Triple 8HT (MDF) is 26" tall, 12.25" wide, 14" deep and 75lbs.
The first batch of 2010 Triple 8's (baltic birch) were 12.75" deep but were measuring to 81hz so I added a the 1/2" of depth to get to 80hz. Not an auditable difference.
The 2009 Triple 12HT/LF was 16.5" deep and the 2010 Triple 12HT is 14" deep.
On my short list of stuff to do is to put together an archive.
post #1565 of 8249
That would be great. I would also like to know the crossover points.
post #1566 of 8249
Jeff please give us some info on the shipping of the new T12s, my hands are itchy
post #1567 of 8249
2010 Triple 12's started shipping Thursday of last week. All speakers currently ordered will be out the door the by the end of this week.
post #1568 of 8249
Just received great news, my Q8s should be shipping this week
Its going to feel like xmas...JTR & Sim2 PJ this week, I'll be busy
--Manny
post #1569 of 8249
Humm, Ross bought them used so I wonder who the original owner was? Jeff is going to have to start using serial numbers .
Yep, I picked them up from the original owner who is a member of this forum - he only had them 2 months so they were as new. The only reason they ended up in ufokillerz' hands is our theater upgrade has been delayed until next year.
Cheers,
Ross
post #1570 of 8249
Getting my 2010 triple 12HT tomorow (hopefully in one pieceu know how carriers can be at times especially with such large merchandise) and i'm so excited. Getting power amplifier thursday went with earthquake cinenova grande 5 and it should be able to power up the jtr with a little over 600 watts.
post #1571 of 8249
Got my two 2010 T-12's today. Only listened for a couple minutes so far, but so far they are MUCH louder than my Salk HT2-TL's. I am pushing them with a 550 wpc icepower amp. They sound pretty good so far, they don't extend very low, definitely need sub's. I am using 2 MFW-15's and a MBM-12. I am really pushing them and im not sure they can hang with the T-12's. I have only listened to music so far. I am not quite used to them, but they don't sound as "refined" as the salks, but thats what i expected. They seem a little more "harsh", but so far it hasn't been too bad. My room is not treated, so I am sure that causes some problems. I think I will try watching a movie now and see how they do.
post #1572 of 8249
I am thinking very hard at ordering triple 12's for LCR. Currently I have the Klipsch RF-83 for front left and front right and the Klipsch RC-64 for the center channel. Link to the manufacturer below.
http://www.klipsch.com/na-en/product...stem-overview/
Wanted to ask how much better these Triple 12's would sound in home theater. I am using the Dennon 4308CI AVR which only has 140 watts per channel. Im guessing I would need more power as well right? I currently have dual Danley DTS-10'S for subs powered by a crest pro 9200 amp. Thanks in advance.
post #1573 of 8249
When you say "refined" do you mean rolled off highs?
post #1574 of 8249
I have not heard the Klipsch, so I can't comment on the difference in sound. However, according to the specifications the sensitivity of the JTR's is equal to that of the Klipsch, and you should get more power out of your receiver with the 4 ohm load of the JTRs than you do with the 8 ohm load of your current speakers. Although the JTRs can handle more power, they may not need it. They should be at least as loud as the Klipsch, assuming the receiver can handle the 4 ohm load. If you get the JTRs I would run them off the receiver first to see how they do before buying additional amplification.
post #1575 of 8249
Kutlow,
I have Q8s for LCR and T8s for Wides. I also have the S8s for surround duty (not yet installed). I'm in the process of assembling my dual DTS-10's. I hope to have them running this next weekend.
I'm expecting that the T12s or Q8s will integrate very nicely with the Q8s. They have plenty of dynamics and midbass impact, at least by my ears. We watched HurtLocker last weekend and even without subwoofers they really hit hard. I can't wait to feel this movie again with the subs installed. We sit relatively close at 10 ft.
I would get a separate amp for the headroom even though these speakers are very efficient but of course you should try first and see for yourself. I also have the Denon 4308CI and I elected from the get go to drive the fronts with an outboard amp and use the internal amps for surround duty and remote locations. I'm completing a full 11.1 setup with a second zone so the additional channels get used.
Hope that helps.
Louis
post #1576 of 8249
Originally Posted by Mathelo View Post
Kutlow,
Hope that helps.
Louis
First congratulations on the dual dts-10's. One little tidbit on the build is to get one almost finished before you put the last panel (P) and have it next to the second one your building. It makes cheating very easy when your not sure how some of the boards go. Also make sure you use spray adheasive and staples on the foam pieces. If not they will flap later.
Can you provide a link to the outboard amp that you use with the 4308CI? How do you hook it up to the 4308CI?
post #1577 of 8249
Kutlow,
Hope that helps.
Louis
wow the way i want my system is like yours, wanted Q8's for LCR, T8's for wide, and S8 for surround, but it will only be a 9.2 when complete, running dual dts-10s. It is one rocking package. have T8's for LCR right now with the pair of DTS-10's, will be getting 3 Q8's sometime in the near future, with the Slanted 8's later on this year probably! The T8's convinced me that JTR is the company for me.
post #1578 of 8249
I would LOVE to see the xmass on the custom woofer in the captivator.
My hum problem might end up being fatal to my attempt at captivator bass bliss (I have one or two final prayers before I have to throw in the towel - DAMN old house wiring!) but this situation has given me a chance to see how the woofer moves and boy does it move. I am coming from an epik dynasty which had an 18" woofer with a very different behavior profile so I have not seen a woofer that gets this kind of throw. IMO a woofer with more throw seems to give more visceral/mid bass impact which I like. Very impressive design for a 12" woofer.
post #1579 of 8249
I had the same thing going on. I contacted Jensen Transformers who makes the high quality products and I was directed to this.
No more humm for me. Call them ask for Dave Hill and he will tell you what model number you need. Mine is called the sub xxx
post #1580 of 8249
Thank you.
I will take your advice - FYI I have tried a lot.
Removed EVERY electrical device on 2 floors of the house. Replaced every AV wire. Tried different wires in every spot I can think of. Bought a power conditioner. Tried different combos of things on the same or different outlets.
The one consistent has been the receiver being in the loop at some junction but this avr has been used with no less that 5-6 subs and an ep2500 (different unit but I have tried an ep2500 and an ep4000 now)
I will let the experts over there try to help because I really want to make these subs work for me but if they don't have a solution the old house wiring might win (and someone near NJ might get a killer sub)
post #1581 of 8249
If the conditioner didn't work it's probably in your ground... cheaper conditioners only just have filters and don't work that well.. but if you tried a really nice conditioner it takes the hot and neutral and converts it to DC using a rectifier and converts it back to AC using an inverter... this is how the more expensive ones do it... the Cheaper ones aren't real conditioners they just try to filter out some of the noise. Even in the actual "real" conditioners the ground is fed straight through untouched so if the problem is with the ground the conditioner won't help at all.
Have you tried (temporarily) taking an old spare cord and removing the ground or using a cheater plug? If it still does it i'd check the conditioner as that should have fixed it or it could be in the amp. I'm assuming it hums even with the signal input (RCA cable) unplugged. If it's in the ground you can always install a dedicated ground just for that outlet... shouldn't cost much but make sure it's up to code.
Thank you.
post #1582 of 8249
Thank you.
Have you disconnected the cable for your TV?
post #1583 of 8249
Kutlow,
I'm using a Wyred 4 Sound 5 channel amp. This is a class D amp that runs cool and is very efficient. I have 500 watts on the LCRs and 250 watts for the wides. I got it second hand so saved a bit on the cost. It works very well although I'm currently using it with a cheater plug. Damn ground loop problem!
Not exactly sure what you are suggesting for the DTS-10 build and it may be too late. I've already installed the P panel on the first build but I've not glued in the A panel. I used cellophane to keep it from sticking and I was able to very easily remove it after flipping the cab over. I've left it open so that I can install the drivers with better access and all the extra insulation I'm putting in before I seal it up.
Louis
post #1584 of 8249
I have a cheater plug on sub amp. The avr, as-eq1, reckhorn and s-converter do not have ground plugs (and I have tried taking them out of the loop one by one except for the receiver). Also the outlet they are connected into does not have a ground plug attached to it.
It only has the white noise when a signal is coming through the AVR - I.E. if it is muted then it stops but if there is nothing coming out (paused movie, cable station I don't have) but not muted then it still comes out. I have changed EVERYTHING even amps.
I tried disconnecting every coax cable on the same circuit as well as mine. Weird thing is the white noise goes on even without the coax in BUT when I watch cable tv I also get an additional thump added in when I change channels and the next channel registers or handshakes through the avr.
Since I have tried so much the ONLY consistent components were the sub and the receiver, everything else in the entire system and house has been disconnected at some point and tested.
From the coax thump and the non-coax dependent, constant white noise, I have 2 problems to deal.
post #1585 of 8249
Can you run a cord to a neighbors house to power the sub.. testing only not permenantly?
All of your commons and grounds are tied together in you panel box.... anything on the ground or common could cause it anywhere in the house (even a coax cable as the sheilds are grounded and therefore the chasis of the cable boxes are grounded to the sheilds) not just in that circuit but any circuit in your house. Because you have no ground on the plug a true power conditioner should solve it...
what method of conditioning does your conditioner use??.. DC to AC conversion (this is also how UPS's "uninteruptable power supply" work only while the AC is converted to DC it charges the batteries before the inverter converts it back to AC, If you have one big enough on a PC or anything you can try it) or your conditioner may use a bank of caps used as filters, I'm assumming the later.
post #1586 of 8249
Conditioner is a cheap $60 furman one that jeff sent me a link for. I don't think he was giving a real solid recommendation but rather just giving me a cheap option.
Would an expensive power filter solution fix this?
I found a 3rd circuit and tried that one too. Can something on another meter in another circuit box in the same house interact with my equipment? Someone did move into another part of the house on another meter and box and he has a good amount of electronics.
post #1587 of 8249
From your description this may not help (as you said the hum changes with volume) but it is worth a try.
The greatest percentage of "groun loop" 60cycle hums in a HT system come from either your cable or you sat not being properly grounded.
To see if this is the case you can perfrom a simple experiment.
1) Turn on your system till you hear the hum.
2) go to the jack on your wall where the cable or sat service enters the room (this is a coaxial f-connector coming out of the wall)
3) unscrew and disconnect at the wall jack
4) if the hum stops then it is the ground and can be cured by placing a filter in the cable line. If it is HD SAT then the filter will not work, and you'll have to figure out how to ground your dish.
post #1588 of 8249
Hey John,
I don't think it is the cable because I still have it when I disconnect my cable from the box and unplug the box.
Can it still be the cable?
EDIT: Also worth knowing, there IS a nasty hum on top of the white noise but the main nasty hum goes away with a cheater plug
post #1589 of 8249
Hey John,
Hum is probably the ground loop. The hiss can be helped by lowering the gain on the amps if you are using separate amps.
post #1590 of 8249
Hey John,
If it is the cable it must be disconneted at the WALL jack for ALL systems in the same house on the same power grid.
If you have cable in another room as soon as you plug it in it can pollute the rest of the house, if on the same grid.
  Back to Forum: Speakers
