Originally Posted by bodhisafa
Multiple things, I need:
processing, amplification and 2 surrounds to go with my triple 12's
Processing budget is less than $1000, just need pre outs and outstanding sound quality for movies, no video upconversion or fancy wide heights.
Amps looking at used pro gear I read crown k2's and behringer tested identical. I like the no fans on k2 and fan mod on behring.
Surrounds can be anything cheap my room is "different" than most makes it hard to place surrounds on back wall, just need something to get by for now.
Looking for any suggestions, Iam new to this not sure whats best
Luis
Luis
I'm running emotiva amps putting only 300w into a 4ohm load. This is what Jeff told me via email
With the JTR efficience, your 300 watts will go a long way and make you "popular" among neighbors, neighbors. If you upper gradeist ever kicks in, you can quadruple your wattage.
i'm sure pro amps will work fine,but i was running near reference levels (-3db) with my amp, and after all of terminator salvation, the amp was not even warm to touch. no fans, no noise, maybe i'll go pro when i need more sound eventually.
