Well, I DO know a guy selling some Submersive HP's...
In my room, I sit around 10 feet from the mains. I should hit 105 dB at the listening position with 80 watts on the Triple 8 accounting for the AT screen attenuation. I have not measured this to confirm. Obviously to go above reference I'd need more power, but I'd like to preserve my hearing
Thanks for the Metallica recommendation, I'll have to pick that up. Is it multichannel?
The variation for the 2 seat next to me, about ~1ft apart is about 3-5dB difference. So, if you want to optimize for everyone, then you will want 2 subs... For 2 subs, you do want to stick with the same brands/models. Otherwise, it gets hard to integrate.
I agree but ... I have the 2009 Rock and Roll Hall of Fame Concert from Madison Square Garden (Bluray, a great system tester) and to get that front row concert feeling on Metallica's Sandman, you need lot's o watts ...
![]() I have the Wyred amp(s) you mentioned and it does make a difference. It will also hasten my inevitable hearing loss ... ![]() ![]() ![]() |
) but their placement in my room that I am not sure about.
I just finished watching battle of LA and it sounds fantastic! very punchy and the voices are really good! A big step up from the Klipsch RC-64 I had to use before because of size conflicts. It's not as big as I thought, but feels like a brick in your hands, it's heavy for it's size. I'm using T12's as my mains and they blend very very well together. It's seamless. Very happy with it!
