Originally Posted by Bassfeen
Hi all,
This may be off topic, I have JTR 2012 Versions 888sealed.
They are running as LCR I am looking to get The Danley Mini for Sourrounds or JBLS
I have an issue with Hiss from the speakers and its getting worse at higher levels. I know its not the JTR its the Emotiva Amps Im using "UPA-1" Mono Blocks.
However, Just wanted some advise on which amps would be a better choice my AV is PR SC 5509 Onkyo.
I am Looking at either the ATI 3005 or Earthquake Cinenova Grande Which would work better?
Hi all,
I'm not to familiar with the Earthquake but I'd give the Outlaw 7900 some serious consideration also as long as you can afford it and power it. Outlaw is made by ATI so they are very similar.
. The Slanted 8's are fairly unobtrusive and can be mounted high enough that they disappear in a dark painted room. In-walls and or in-ceiling speakers would be a bad match and poor choice IMO.
But the theater is not "about finished". I still have seating riser to finish, false screen wall to build, mount projector, etc, etc... The list of things to do doesn't seem to be growing shorter very quickly.
