AVS › AVS Forum › Audio › Speakers › Official JTR speaker thread
Official JTR speaker thread - Page 139
post #4141 of 8257
Hey guys, I owned both the new T8 LP and the original T8's and I like the newer version better. They have more feel to the music if that makes any sense. BTW, they will play fine at 80hz if ones needs that crossover. Jeff makes damn good products and we are lucky to have him as a part of our community. I believe Jeff, Mark Seaton, and Danley have taken HT to a new level and paved the way for other companies to follow along with cheaper iterations like eD and CHT. You can always try JBL pro or something like that but they are enormous so all I can say is that HT has never been better!
post #4142 of 8257
Audyssey XT crossed my T8 LPs @ 80hz when I first ran it.
I ran Audyssey a few months later and it crossed them @ 70hz. Not sure if they were just more broken in or what.
PS...I have my T8s- Lp listed in the forsale section if anyone is interested.
post #4143 of 8257
Originally Posted by giomania View Post
For what it's worth, the crossover on my 2012 T12HT-LP (sealed versions) wound up at 80Hz. I have four Seaton SubMersive HP subs, so the crossover could easily have been higher on the T12's.
Mark
Hi giomania, Like to hear your thoughts on the t12lp's sealed. Just this week i ordered them myself, have not read anything about them here. I'm using them in my dedicated theater room, the room is treated and is about 3000cf. Thanks!
post #4144 of 8257
post #4145 of 8257
BTW, nice review Mike. How about some photos of the setup?
At your request, RMK.
Not readily apparent in the frontal shots are the big subs. The Captivator lurks hidden away in the left front corner while the PB13 inconspicuously serves as an end table. They are not so much seen, but easily felt.
I might power up the RS850's with an currently unused amp that's sitting in the rack. Then I can switch to them for a slightly different audio flavor if the mood strikes.
post #4146 of 8257
Originally Posted by thebuckaman View Post
New additions arrived today. Glad I went with t12x pros (metal grills) as I knew my daughter would love to "explore" them. Single 8x pro for center. Did some Basic listening tonight and im VERY happy with what I am hearing after xt32. I'm back in the JTR game!
Attachment 245261
Cool! Good to hear your going to have a system again. Are you going with JTR subs again?
post #4147 of 8257
If you do not mind me asking, why are you selling them?
post #4148 of 8257
Originally Posted by mojomike View Post
The only frequency measurements that I have kept were SMS screen shots that I took when I first set up my Captivator back in 12/10. They have nothing to do with the F-mods and don't at all reflect their effect on the system. The F-mods only effect the relationship between the L&R mains and the small stereo subs. I can say that I've never had any frequency anomolies using the F-mods. Below is a screen shot of the Captivator + the PB13. This is prior to applying any eq or Audyssey.
The difference between the freq response graph on the sms-1 and the xtz room analyzer was huge in my room. The xtz showed a lot more peaks and dips than the sms-1 did. When I made a slight eq change on the sms-1 I could see the change very easily when I measured with the xtz, but on the sms-1 graph it was much harder to see. I love the sms-1 for making eq changes but for actually seeing what is going on in the room I don't think it is useful.
post #4149 of 8257
I upgraded to Triad Gold LCRs (newer versions) but got them used at a great price. In my small room (1150cu ft), I feel this is an upgrade but my thoughts might be different if my room was much bigger (2500cu ft or bigger). Its possible the dynamics of the JTR would pull ahead in a larger room.
Keep in mind the Triads new are double the price of the JTRs new.
post #4150 of 8257
The SMS-1's graph has a lot of smoothing, I think it's like 1/3 or something. You probably ran a higher resolution graph with the XTZ which will undoubtedly show a more true response. In reality a difference of +/- 3db is not going to make a huge difference to most people. We definitely are not most people on this forum though
I have used the Omnimic and REW in conjunction with the SMS-1 and it's true there is a difference but not enough to put up with the added steps involved. To me the SMS-1 was close enough and once you know the difference you know how to read the SMS-1 graph more accurately.
post #4151 of 8257
The frontal shots were apparent to me What is that movie anyway?
post #4152 of 8257
I was thinking it was a home movie ...
post #4153 of 8257
Maybe there is something wrong with my sms-1 microphone because it was maddening trying to get a flatter response until I used the xtz.
post #4154 of 8257
Do you like my wife's wings? Actually, it's sci-fi/horror movie called "Splice" which just happened to be on the tube when I switched it on for the photos.
http://www.imdb.com/title/tt1017460/
post #4155 of 8257
The SMS-1 screen graph resolution is quite low compared with XTX or REW. It sort of ignores very narrow band frequency anomolies, but it also seems to reflect the way we actually tend to hear things. Our ears also are not sensitive to very narrow band changes.
post #4156 of 8257
I agree.
post #4157 of 8257
Never watched Splice, looked a little freaky, apparently I was right
post #4158 of 8257
Check out the alien/angel winged girl from splice in human form, might have to check out that movie after all
post #4159 of 8257
I just wanted to share my somewhat crude implementation of a Slanted 8 mounting solution for the height channel speakers. I used some OSB I had scraps of and built a triangular shaped bracket that is screwed into the ceiling, and the Slanted 8 is hanging off of that bracket. They actually look pretty cool from the front, as they appear to be floating in the air.
In case anyone is wondering, those are 2011 Triple 12HT-LP's in the L, C, R, Wides and Surround locations. I have some close-up pictures of the T12 drivers if anyone is interested in seeing them. Perhaps they have been posted here before already.
Mark
I have 7 each 2011 T12HT-LP's (L, C, R, Wides, Surrounds) and 4 each 2011 Slanted 8's (Heights and Rear Surrounds) with four SubMersive HP's.
For amplification, I used my existing 5-channel Classe' CAV-180 (L, C, R, Wides), a two-channel Proceed BPA-2 (Surrounds), and four channels of my Denon AVR-4311CI powering the Heights and Rear Surrounds.
I may be biased, but I think it sounds great!
Mark
The room is ~27' x 21' (4300 Cubic Feet)
Two SubMersives are behind the screen wall, and two are just in front of the surround speakers. Attached are some pictures.
Mark
Chong,
Here is what I have: 7 each 2011 T12HT-LP's (L, C, R, Wides, Surrounds) and 4 each 2011 Slanted 8's (Heights and Rear Surrounds) with four SubMersive HP's.
So, my Surrounds (TH12HT-LP) and Rear Surround (aka Surround Back) speakers (Slanted 8's) are different. I really debated the need for the TH12HT-LP's as surround speakers, but they did not cost that much more than the Slanted 8's, so I went for it.
Mark
I have added some pictures of the rear of the room with the Slanted 8's.
I have 20" stands for my mains and wides, to have the center of the center-mounted T12HT-LP coax at 39" from the floor. I filled them with sand to weigh them down and increase stability.
The T12HT-LP surrounds have the coax mounted on the top and are on 24" stands.
Mark
I chose the T12 HT-LP, as I wanted all the speakers to match, and my Wide and Surround position speakers are up against the wall in my room. The L/C/R position speakers are in front of my screen wall, and away from the boundaries. In my room, I wound up with an 80 Hz crossover on all the T12 HT-LP's.
Food for thought.
Mark
I have a Denon AVR-4311CI with Audyssey MultEQ XT32, which is designed for calibrating two subwoofers. In my setup, both "pairs" of Subs are in "matchbook" locations in the room. Then, each of the "pairs" is connected to one of the subwoofer outputs with a "Y" cord.
So, Subwoofer 1 output drives two subs (pair #1), and Subwoofer output 2 also drives two subs (pair #2).
I hope this helps.
Dragon, I have quoted a bunch of my posts on my system setup above (Click on the link to see any pictures posted), and will add the following:
I upgraded from 11-year old 7.4 Mirage Omnipolar system to the 11.4 JTR setup noted above. What I am saying is that in my case, the upgrade was significant, so keep that in mind My viewing/listening habits are currently 100% movies.
I also had Mark Seaton perform my Audyssey Pro calibration, so be assured he squeezed every last ounce of performance out of my setup. Mark is very meticulous and was at my house for 11 hours total! He first takes the Audyssey measurements. Next, he uses acoustic measurement tools & software to adjust the sub distance, ensuring the best output at the selected crossover frequency. Finally, he starts tweaking the Audyssey Pro target curve, loads the changes, and then listens to program material to check the result. He repeats this last step numerous times until he is happy with the result.
What I have noticed in my new setup versus the old, is how much more accurate the system is; a poorly recorded soundtrack is noticeable. For example, this past weekend, we watched "Insidious", and I noticed a lot of the dialogue in one particular filming location of the movie sounded terrible with echoes. It changed when the filming switched to a different location, so it may have been the director's intent, that particular set, or a re-dub perhaps. Anyway, I like the accuracy in JTR setup.
The other thing I like is the dynamics / realism. I tend to jump a lot more now if I don't know something is coming, as the sound just has a lot of impact.
I hope this helps.
Mark
post #4160 of 8257
I REALLY liked the SMS-1 (owned several) and miss it for the ease of use, multiple settings and remote switching. I am now a slave to Audyssey XT32 and it's mysterious process. Blind Faith or quite possibly Expectancy Bias is at play here.
post #4161 of 8257
I let Audyssey do most of my eq'ing, but I use the SMS-1 for initially tweaking the crossovers and the phase particularly to get all the various different subs playing nicely with each other. After Audyssey does it's thing, I then use the SMS to create custom pre-sets for different circumstances such as for movies or music that are weak on bass. It's also nice to be able to easily raise and lower bass levels by remote and then be able to easily reset them back to normal.
post #4162 of 8257
Do you have XT32? It supports two distinct sub outs (Integra 80.3) and running those through an SMS-1 with mono output defeats the purpose. I suppose I could look at the output of one sub at a time, but I would only be able to adjust one of the subs FR, levels and phase relative to the combined output. Sounds like a useless exercise to me. Now, a dual sub SMS-1 would get my attention.
post #4163 of 8257
Onkyo/Integra's implementation of Audyssey XT and XT32 pretty much makes most sub EQ's no longer necessary. I wouldn't use the SMS-1 if I didn't need to apply boost down low to my DIY subs.
Here is what the response looks like with only XT32 out of the Onkyo 5508. Notice how they only filter I have moved on the SMS-1 is the 3db boost at 16hz which was later maxed out at +6db:
The odd thing though is I did have to use the SMS-1 to fix the response after running XT32 with a Denon 4311. The Onkyo 886 with regular XT did a better job on the subs that the 4311, I had them both at the same time.
post #4164 of 8257
Unfortunately I only have Mult-EQ at this time. A new AVR with XT32 is certainly in my future. I eq my two LFE subs as a unit and the stereo subs get eq'ed by Audyssey as part of the L&R front channels. I use the PB13's phase control to align it with the Captivator, then further adjust the phase of the two together as needed using the SMS-1.
post #4165 of 8257
XT32 EQ's all the subs as a single source as well, the only difference is it first sets the levels and distance (phase) separately.
post #4166 of 8257
Ahh, I see. I could certainly make use of the separate distance and level controls.
post #4167 of 8257
That, plus the secret EQ sauce is the value of XT32.
The real time FR display of the SMS-1 (as well as the other nice features you mentioned) is what is cool about the SMS-1.
Waiting for that SMS-2
post #4168 of 8257
That is my understanding as well and I believe these are set after the first measurements. I have to wonder why XT32 continues to ping the subs separately for all of the other position measurements and not just do the combined response?
post #4169 of 8257
I have 2 SMS-1 but for some reason that doesn't equal a SMS-2
I am hoping they are making a SMS-2, as long as it is not insanely priced I would be in.
post #4170 of 8257
Your right in that it is set after the first measurement, it pings sub 1, then sub 2 then a third ping which is the combined response. After the first measurement though it only pings them both at the same time on each consecutive measurement.
The only time to EQ subs separately is when they are being fed a different signals like mojomike has set-up with his SVS subs. When they are being fed the LFE signal then they must be EQ-ed as one since they are getting the same signal.
XT32 really is remarkable at how well it EQ's the subs, it would take hours to duplicate what it does in minutes.
  Back to Forum: Speakers
