Originally Posted by MX48
I know it can be a pain but you guys should really get REW or an Omnimic or similar. It is a real eye opener as to what you are hearing, where your peaks and valleys are in your frequency response and what your personal listening preferences are.
It is definitely worth the time to implement it. Once you start running graphs it can become addictive tho
I am guessing you are correct in that the "edginess" is from a peak in the voicing area, but you may be cutting way more than need be. You won't know until you run graphs. Of course if you are happy with it now there is something to be said for not digging too deep
Moto
.I am guessing you are correct in that the "edginess" is from a peak in the voicing area, but you may be cutting way more than need be. You won't know until you run graphs. Of course if you are happy with it now there is something to be said for not digging too deep
.Moto
You make a very valid point. When I altered the response, I was pretty much winging it and trusting my ears. I very much liked the result, but it certainly is not the most scientific approach. I used to be an REW user, but only for the purpose of eq'ing the subs. I've never used it full range. When I got an SMS-1 for the subs, I quit using REW altogther. It might be time to breakout the laptop, etc.
