Originally Posted by dholmes54
If I get 3 attenuators for my 3 front triple 12s,I think it was stated that I use -10 db attenuators for best results,just install them & re-run audyssey & see what happens?Do I just plug the attenuators into my amps xlr inputs & plug the xlp cable into the other end? thanks ps I guess for 30.00 $ its worth a try!!
That's it. I installed the attenuators on my SSP end (due to allowable space) but no matter. The attenuators will drop the level of your T12 LCR's 10db. Re-running Audyssey should set the levels to 75db. Adjust the crossovers to your preferred settings and check all the speaker levels with an SPL meter and you should be good to go.
Edited by RMK! - 11/4/12 at 8:50am
) we are thinking of taking several pieces of equipment (my Caps, and a few other selections of local speakers owned by enthusiasts) out to a local shelter house (one isolated as much as possible of course) and spending an afternoon barbequing and listening to to a selection of speakers outside with good food, good drinks, and good company!
Still, I can't help daydreaming about the Noesis for the front 3 for movies and a pair of LS-6's for music... and I haven't even heard either yet. I have a problem.
