Originally Posted by cmryan821
I haven't received my JTR's yet but everyone seems to say the same thing about them: they don't need alot of power but they sure do like it. Now I'm not at all familiar with the SC-05/07 but if it has no issues with a 4ohm load then it should do the trick.
As for separate amps, many guys are happy with emotiva and it doesn't break the bank(the back maybe). Alternatively, you could look into some pro amps. Jeff recommended a few on his forum a while back. http://jtrspeakers.websitetoolbox.com/post?id=3546215
And you could always email Jeff. He's busy as hell but he always gets back to you eventually and usually very quickly. Hope this helped.
Well quite a few people run 4ohm speakers with the SC-05 / SC-07 but it is not officialy rated for it. Now different speakers spend different amount of time down at 4ohm - don't know the technical terms for putting that correctly so that is why I was asking for some specific JTR input.
I think I might go ahead and buy them and just be mentally (and financially) ready to get an amplifier if they start clipping.......
EDIT: I couldn't see if the Triple 8's are rear or front ported - maybe that is a given for you guys that are a bit smarter but not for me. The distance to the back-wall is a concern for me
-- so I guess that means a 3 Channel amplifier
) for a very long period of time to have any chance of damaging the speakers, particularly if you have them crossed at 80Hz. Short of poking something through the cones, the T8s are more likely to hurt you than you hurt them.
