Originally Posted by N8DOGG
Sure tube amps will "usually" have more distortion than a SS amp but that doesn't man it's always audible. Unless I'm/anyone is doing a blind A/B test in the proper conditions, there is no way to tell vs anything else. You can't judge by memory. Nothing stuck out as different and if it did? I'd likely be just wanting it to in the first place.
It's not always audible but it usually is, so we'll agree to disagree on that one. Although, I do agree some tubes have less distortion than others.
I know a lot of people who could pass a blind test of tubes vs. SS (and already have). Distortion is very audible if you know what to listen for.
Originally Posted by dlbeck
Iowa GTG will be on Jan 5th. See here for details on the event....all kinds of JTR goodness (and others)
http://www.avsforum.com/t/871474/ia-meet/3420#post_22677212
Thanks, David.
Originally Posted by countryWV
The 4311 has plenty of power for a GTG. It wlil also drive 4,6,8 ohm speakers equally as well. Some lower model avr mabey not so much on LE speakers.
How do you go about doing a blind test with HE against LE? Would not the volume have to be limited? I guess you could do the volume level blind also. Just curious as to your plans.
Did I read you all will be using a pair of S2's. Noesis and Salks crossed over to a pair of Cap S2's sounds like a full day all by itself. I feel sorry for any other speakers that attend.
I hope your GTG does not ruin your Christmas excitement. I know I don't even like to go on vacation anymore.
Chris
Chris
You're dead on. This won't be a simple swap and listen scenario, as each speaker will need to be re-level matched between listening sessions, and the subs will have to be re-adjusted as well. Someone could shell out 2 grand and purchase that A/B switcher from Van Alstine, which allows you to level match the speakers before starting the listen sessions, allowing you to just hit the remote swap button and you're done. Come on...only 2 thousand guys!
