Would a denon 4520ci good enough to power the noesis front 3?
post #6331 of 8265
12/25/12 at 9:47am
and only the knowledge that I have Neosis's on the way as their replacements makes my long wait bearable.
also, you think you have bass now, those caps are going to kill you. When you looked at your AVR at -29.5 and it hasn't been calibrated, that can be very misleading. After Audyssey, it will usually set the T-12's at -12dB to get them attenuated enough. If your speaker trims are already set above 0 for L/R, then I can easily see how -29.5 dB is too loud for you.
I still feel like a dumbass.
