AVS › AVS Forum › Audio › Speakers › Official JTR speaker thread
Official JTR speaker thread - Page 23
post #661 of 8265
So I've pretty much decided to go with the Quint 8's as I've discussed earlier. I don't need the furniture grade finish for my cabinet install but I'm thinking it might be worthwhile for resale if I ever need to sell these.
What would you do? Is it worth the upgrade or should I just save the cash for something else?
Louis
post #662 of 8265
Me again ;-)
This is a from scratch new build so I have a lot of decisioms to make. For an AVR I've decided to go with the Denon 4810CI and implement 11.1 as quickly as possible. As such, I need to decide on what I'll use for all the surround channels. I'm less concerned about the side, rears, and heights, but it seems that the wides become the most critical additional speaker in this configuration.
My thinking is that a pair of the T8s would be best but probably overkill not to mention taking up more space and dollars then I really want to part with for this application.
On the otherhand, the Slant 8HT might work well for this application even though it rolls off on the low end. What do you guys think? Should that be a concern?
Thanks again!
Louis
post #663 of 8265
Originally Posted by gpmbc View Post
Sound thinking Louis. I am actually using a combo of 888s for L & R and the Triple 12LF for center. I am also ordering 2)DTS-10s nearfield and a Growler up front. In my room its 22 feet from the back wall to the front of the screen. The screen is acoustically transparent and in front of a 36" tall dividing wall which is the only thing separating the next room which has another 20 feet behind it. My speakers are on a platform in between the 2 rooms so the wall behind the speakers is 20 feet away which means next to no support from the room. My thinking was to add the Growler (long throw and able to hang with the DTS-10 in output and sensitivity) up front to reinforce the 888s and the DTS-10s to serve as riser and handle the rest. My receiver has 2 LFE outputs so should make integration easier.
Hi gpmbc,
That is an interesting approach with the T8 combo and T12 center. Did you just happen into this or was it by design? I can see some benefit in adding the T12 to the mix. I could even go with 2 Q8s with a T12.
Louis
post #664 of 8265
i am no pro on 11.1 but as long as the speaker is rated for 80 hz and it is than it should work great . jeff is comming out this weekend cant wait .
anyone else with a 8 and a 12 have anyfeedback
post #665 of 8265
Very nice setup MLJ, this is OT but how do you like the Seymour screen. I am thinking of getting one of their fixed models (120"W) to use with my HD-100 (RS2). I know it's a little shy on the light output but I am holding off on a PJ replacement.
I like the Seymour screen a lot. The moire I was getting with my old screen is completely gone with the new XD material. I can barely notice the screen texture from about 8' away when it is a very bright scene. For the cost, its a no brainer. UMR has a screen comparison thread in the screen forum and he has tested it. It is fairly color neutral and the acoustic properties seem to be pretty good.
The RS2 is still a great looking projector and should do well with a Seymour screen.
post #666 of 8265
I wonder if JTR will ever make a dipole-bipole spk or a bookshelf spk, maybe a double 8!!
post #667 of 8265
I've been wondering the same thing but I don't think this speaker design lends itself to bi/di-pole given the coax design. I'm sure it could be done with 2 of the coax units but it would get bulky and - at least for me - end up being more than I'd want to spend on a surround.
Louis
post #668 of 8265
Thanks I wanted to get rid of my Polk fx1000s & maybe get the slanted 8s for a sonic match but I dont really think matching surrounds to front is that important.Im thinking about changing the drivers in the polks to the brand jtr uses but I dont think it would work.Oh I have triple 12 for lcr.
post #669 of 8265
Mathelo one of the guys on the forum i think it is slowcar or slow something he had the 8 and 12 and slanted 8 and was running the 11.1 set up but he did not keep it . if i find his name maybe you could get some info from him he has been there done that .
post #670 of 8265
Steve,
That would be good to know!
Louis
post #671 of 8265
Hint: Take a look at the first post of this thread He doesn't have the T8's anymore though, but I think he's still using the T12 as a center.
post #672 of 8265
found him http://www.avsforum.com/avs-vb/showthread.php?t=1092343
i know he does not have them anymore but he ran a 11.1 system he would be the guy to ask he has done it
post #673 of 8265
Disclaimer: What is written below is completly my uneducated opinion regaring the usefullness of Dipole-Bipole speakers in a modern home theater system. Take anything you read below with several grains of salt.
Bipole-Dipole speakers have outgrown their usefulness. They were fine for Dolby Prologic, but it is detrimental to true multichannel surroud. I think a Dipole-Bipole speaker would be vastly inferior to a Slant 8 or Triple 8 surround.
Have you ever listened to music on your Dipole surrounds. If not, try it and see if that is what you would like your surround channels to sound like.
Today's sound tracks include discrete surround information. There is no need to try to get a diffuse soundfield unless you are using a matrixed source like a VHS tape with Dolby Prologic.
Movie theaters use monopole surrounds, just several of them per side. From what I understand, mixing studios use monopole surrounds. There is no reason to try to make the sound bounce around behind you. Almost any monopole will beat a Dipole for creating a good surround experience. A wide dispersion, efficent, speaker such as any of the JTR models will do even better.
On the other hand, a Double 8 might be interesting.
post #674 of 8265
I thought he was going to make a single 8 for small rooms or was that Soundood hoping for one. What ever happened to him.
post #675 of 8265
Jedirun,
There is an interesting thread somewhere here on AVS going at this topic at length and the general conclusion was ... it depends.
The depends had a lot to do with the size of the listening environment - monopoles work better in large live listening rooms - and how large a sweet spot you are expecting. Di / Bi-pole being better for a large sweet spot. Modern recording techniques do seem to make more of a difference as well.
At this time, I have zero experience with either so am at a disadvantage but I see the theory of monopoles being frequently overridden by the practical merits of di / bi-poles.
In my case, my listening room is a pretty good size (21x21) and the surrounds will have to be at ceiling height, so monopoles might work the best. Its just defficult to test without buying two sets of speakers.
Louis
post #676 of 8265
Isn't the Slant 8 a single 8 or do you mean a Double 8?
Louis
post #677 of 8265
Originally Posted by datgai View Post
hint: Take a look at the first post of this thread he doesn't have the t8's anymore though, but i think he's still using the t12 as a center.
lol
post #678 of 8265
Louis
A slant 8 is angled for surround duty and hangs on the wall. The single 8 was going to be a bookshelf or rectangle speaker.
post #679 of 8265
Thanks jedirum,anyone use the slanted 8s for surround?I was wondering about there 100-20000 hz freq response & sq.My room is fairly small at 24x11.5x8.5 ft,you make a good point about the newer hd sound,my surrounds dont sound as good as they use to.
post #680 of 8265
Got it. I asked Jeff about this in an email yesterday and he made it sound like he would accomodate this request. My ceiling is already slanted so a Slant 8 would have my surrounds almost pointing directly at the floor. In any case, I really want to flush mount them.
Louis
post #681 of 8265
I've got a pair but I have them crossed at 80hz with no issues.
post #682 of 8265
The 2010 Slanted8s have a -3db of 80hz
http://jtrspeakers.websitetoolbox.com/post?id=3614872
post #683 of 8265
Are you using them as Wides?
post #684 of 8265
thanks,that makes the slanted 8s more interesting.Theres a couple of sellers in the classifieds with 888s & slanted 8s but i dont know if they are the 2010 models I need to pm them both.
post #685 of 8265
No. As surrounds. If you used them as wides, you could probably just rotate them and wall mount them rather than having to toe them in.
post #686 of 8265
Yea, that's pretty much what I was thinking. Given my room dimensions (21' wide) it would be easy enough to mount them to the side walls.
So, I looked back at your early email. It seems you have them in the rear. Any issues with this monopole setup?
Louis
post #687 of 8265
Hi gpmbc,
Louis
Hey Louis it just kind of worked out that way. I started with 3) Triple 12LFs and at my previous house with the room sealed I was good. The new house is so open that my impact suffered so I sold 2 of Triple 12LFs. I figured I'd get the 888s and only run them to about 120 augmented with some added midbass and get that impact back if not more while still having a pretty consistent sound across the front stage.
post #688 of 8265
jeff needs to change model numbers when he changes desighns i see the 8 where upgraded in 09 ? and are called 2010 ? new mid driver and crossover same with the surrounds . why not the triple 8 m or something triple 8 c how do you determan the difference in model changes . alot for sale used they could call them what ever they want . anyone know .
post #689 of 8265
2009 T8, 2010 T8. He uses this nomenclature.
post #690 of 8265
are they stamped on the speaker somewhere ? the 2010 just came out correct ?
  Back to Forum: Speakers
