Originally Posted by N8DOGG
Carp just please run all your driver to near xmax before you install them for at least 10 mins each. I see so many guys just check to make sure they'll do anything and install them. Make sure you give them some power and really get them moving free air before you install them into their boxes. Having done this 100's of times and numerous failures, it's such a pain in the butt once they are installed. At least if you have one making noise, you can send them back now and not later.
As for golf, I got my handicap down to 8 this year and am pretty happy about it. I only have 5-6 months a year to golf and I got out over 20 times this year, I'm happy about that, though the wife maybe not so much haha
Wow, 10 minutes? I was running a 10 hz test tone at 8 under reference using the left main speaker wire from my receiver. Should I use this volume and hz or use a higher freq tone? I won't hurt the driver?
. I've got two rows and an AT screen with the screen is 23" off of the floor. I put the L&R on top of the Orbit Shifters and the Center is on a custom stand I built that is the same height. The LCR's are 24" off the floor and that makes the center of he Noesis another 19" above that or 43" off the floor. That's slightly above ideal for the front row and slightly below for the back row. Ideally, I would have made everything a few inches lower but the OS's dictated this height.
