Originally Posted by KevinH
Got an email from Jeff that my 3TXs will probably be finished up by week's end!
Somebody needs to buy my T8s
Coach, doing the upgrade is not hard, just takes a bit of time. And I promise working inside the T12s will be much easier than working inside the small 2010 T8 cabs. I had to change some wiring when I did my upgrade and had to go get some crimp connectors and then just make sure all wiring is long enough before screwing down the xover.
Blazing new trails are we?
I'm interested in why you chose these over the Noesis 212's. My apologies if you explained this in an earlier post.
