AVS › AVS Forum › Audio › Speakers › Official JTR speaker thread
Official JTR speaker thread - Page 255
post #7621 of 8252
Originally Posted by countryWV View Post
Originally Posted by jbrown15 View Post
What I really wish Jeff had was a HT version of the Noesis 2TX to bridge the gap between the 212HT and the 228HT. I know Kevin is using the 2TX for HT use, but I would prefer an actual HT version with the woofers in the same configuration as the rest of the HT Noesis speakers.
As the year goes on I suspect there will be even more New exciting offerings from Jeff. wink.gif
Alot more People are talking about JTR products these days.
Chris
The 2TX and the 228HT use the same compression driver. The 8" vs. 10" midbass drivers are immaterial for home theater use. We had to turn the 228HT to about 8 above reference to get them rocking. At reference they don't even visibly move, and they do play flat to 70hz.
From my understanding - bridging the gap between the 228HT and the 212HT is the difference in a ~$150 compression driver that plays down to about 1000hz and a ~$700 compression driver that plays down to about 400hz (corrected by Jeff - I was mistakenly thinking 600hz). I'd wager that if Jeff put the expensive compression driver in a cab with the two triple 8" woofers the difference between the 212HT and the 228HT would be pretty much indistinguishable for home use. This is my opinion and guess. I could be wrong.
NOW -- powering an auditorium for DJ use? - - - yeah the pair of 12" drivers greater power handling would likely come into play.
Edited by Archaea - 3/8/13 at 7:38pm
post #7622 of 8252
Originally Posted by pianoman88 View Post
Need immediate help please!! I've been eying the AE and BMS group buys and am seriously thinking about building LCR speakers - so 3 total. I was going to do one of the SEOS 12 builds from the DIY forum. But after reading about these JTR speakers and that there are several people interested in or have already done their own versions of JTR, I'm very interested in the 212. The main reason is that I recall hearing the Klipsch RF7 vs the RF5, RF3 (yeah, it was some years back!) and I'll never forget how much smoother, more natural and effortless the sound was from the RF7's. They were the only model in the series that used a 1.4" compression driver with the appropriate sized (i.e., lareger) horn. All the others used a 1" compression driver.
The BMS deadline is now this coming Monday, correct?
The AE deadline is tonight -- order must be PM'ed by 11 PM! So I gotta make up mu mind quick re: should I be purchasing some AE's tonight? (Don't know if I'll do the dual 12" version or the dual 10" version, btw.)
Does anyone know the costs of the AE 12" and 10" drivers? Or the cost of the BMS 1.4" and the 1" CD's?
Also, any recommendations you'd like to make are welcome as well. Thanks!
Can you get the same BMS driver that's in the Noesis 212? I believe it's the 4593 ND, and I think it's around 700 or so with no discount. Someone correct me if that's wrong.
post #7623 of 8252
Originally Posted by Archaea View Post
The 2TX and the 228HT use the same compression driver. The 8" vs. 10" midbass drivers are immaterial for home theater use. We had to turn the 228HT to about 8 above reference to get them moving.
From my understanding - bridging the gap between the 228HT and the 212HT is the difference in a $150 compression driver that plays down to about 1000hz and a $700 compression driver that plays down to about 600hz. I'd wager that if Jeff put the expensive compression driver in a cab with the two triple 8" woofers the difference between the 212HT and the 228HT would be pretty much indistinguishable for home use.
The other advantage is using a lower crossover with the 212's, I'm flat to 55hz in my room. However, most people cross at 80hz anyway.
post #7624 of 8252
Ok, break time is over. Back to building subs. Man, this feels like a full time job.
post #7625 of 8252
Yes, that's what I'm getting, though I believe I read somewhere from the BMS fellow himself (name escapes me ATM) that there is some advantage to the 4594 over the 4593. In any case, I can figure that out later.
Think I'm going to go with 6 12" and 6 10" and if I end up using the 10"-ers in the LCR, I'll just have to sell the 12"-ers. If I use the 12"in the LCR, then I could build as much as a 9.1 or 9.2 system I guess. eek.giftongue.gif
Actually, 5.x is all I'm looking for really... 7.x at the most. But I can sell the extras. Actually, I just realized that is going to be quite a bit of $$$ isn't it? rolleyes.gif About $2600+/- just for the AE's. Oh well...guess I'd better decide and get my PM in before 11. Cheers!
post #7626 of 8252
From my understanding - bridging the gap between the 228HT and the 212HT is the difference in a ~$150 compression driver that plays down to about 1000hz and a ~$700 compression driver that plays down to about 600hz..
post #7627 of 8252
Corrected in the orginal post! (post 7621) -- sorry I got that mixed up!
Thanks Jeff! Good to see you here!
post #7628 of 8252
Originally Posted by Jeff Permanian View Post
Jeff, is the 3TX down to 400Hz as well?
post #7629 of 8252
Originally Posted by Jedirun View Post
No soldering. They are quick disconnect terminals.
Thank you. That was so much easier than I expected. Got them both done in just a few minutes. Now I only need 19" stands instead of 27". biggrin.gif
post #7630 of 8252
I need to run speaker wire up tto maybe 25 feet what gauge works for you with these
post #7631 of 8252
12awg will be more than fine.
post #7632 of 8252
So I've noticed that my electrical panel door has started rattling a bit in my theater. Anyone have any suggestions on how to stop something like that from rattling? Like if I put my hand on the door during a loud bass scene it is fine, but sometimes I can hear it rattling in some loud scenes.
post #7633 of 8252
put gasket tape around door, it will make a tighter fit and stop it from rattling. I had to doi that to mine also. Thing sounded like a jet talking off in the other room hahaha
post #7634 of 8252
line the door with gasket tape
post #7635 of 8252
Hmm so what B&M stores do I find this gasket tape? Never heard of it. I just searched HD and Lowes website with no results. I do see some on Amazon though. I'd just prefer to go run out and snag it though.
EDIT:
Unless "foam tape" is the same thing?
post #7636 of 8252
EDIT:
same stuff, just make sure that the foam tape fits under the panel, and the panel will still lock properly.
post #7637 of 8252
Okay cool I'm gonna head to home depot and check it out in a bit and see how it works!
post #7638 of 8252
I'm close to closing in on LCR of 228HT's for my home theater (single 8's/slant 8's sides&rear in a 7.1). I get that they are great at reference but what about say normal levels of listening. I know this is subjective, lets call it typical waf listening levels. things like voice articulation, music score in films. My wife will never watch a movie close to reference. currently have B&W 804's plus HTMC4 center for the three up front and they do a pretty good job at lower listening, though the other night while watching Avengers BD, they were a bit harsh and weak on the really loud scenes (like near end battle with lots of glass shattering)... So are the JTR's for those loud rocking sounds or can they be subtle and detailed at lower listening as well. I don't have the opportunity to listen before buying
I re-read this post last night after the PM as your comment about the glass shattering jogged my memory. Most of us who do HT know the War of the Worlds POD's emerging scene for the big bass impact but I have always found the window glass shattering and the "Jeep toss" (when it lands upside down) as a good gauge of a speakers HF capability. With my Revels and my original T12's the window glass shattering/Jeep toss caused me to wince at reference levels. As Jeff up graded the CD's and crossover design of the T12's those elements of that chapter became more tolerable. With the Noesis there is no longer any speaker induced harshness in that scene.
With its big dynamic range that chapter provides a good test for a speakers dynamic range capability as well as your subwoofers performance. IMHO smile.gif
post #7639 of 8252
Totally agree RMK. I noticed that with my T8s.........then it was better/smoother after the CD-xover upgrade with the T8s. I now need to watch it over with the 3TXs. cool.gif
post #7640 of 8252
RMK,
Since you have 2 rows of seats, where did you position your side surrounds relative to the two rows? Specifically, are they in line with your front row or between the 2 rows? Do you notice much of a difference with in the surround experience when sitting in the front row, versus the back row. Thank you.
post #7641 of 8252
RMK,
The side surrounds are slightly behind the front row with the CD approx 1' above seated head height. They are a couple of feet in front of the back row with the CD at ear height.
I EQ'd the system with a front row priority (the owners box if you will wink.gif ) and so I prefer the sound there. The differences are slight and at this point, all seats have good to great surround sound.
post #7642 of 8252
Thank you. I am going back and forth, deciding whether to optimize the placement for the front tow and let the (planned) back row make due with whatever happens, versus a compromise between the rows. The compromise between the rows, speakers centered about 1-2 feet behind the front row, will be more asthetically pleasing, so it may be the best choice, especially if the differences will be small.
I will likely optimize Audyssey for the front row and not even involve the back row in measurements. This will likely be the kid's seats and they will not notice the difference.
post #7643 of 8252
That was pretty much my thought process with Audyssey although I did take two measurements 2' behind the two center front row seats.
I don't think the exact position of the side surrounds is criticaI. I'd be willing to bet that like my room, any SQ differences between rows in yours will be negligable.
post #7644 of 8252
I have my theater optimized for the front row, and more specifically MY seat only really. Even with enthusiasts who have come to demo the system, they have said it "all" sounds good from front or back row, and my room is a little more tricky than say RMK's as I have VERY little width to work with so side placements I had to sacrifice somewhere, and with the time and effort me myself and I have put into the theater, I wasn't going to sacrifice the MLP one single iota. For the casual listener they have never even noticed a difference even when I have adjusted the sound to work a little better for a "Big" viewing party. I say your thinking is right on with making it work best for where you plan on being while watching.
Another note on side placements is they should be relatively wide dispersion (if you are using s8/t8 etc then you're in fine shape) to distribute the sound and the closer you can get to on-axis with them, the better, but it still pretty easy to accomplish an acceptable sound from front to back row with them optimally placed (technically) for the front row...Unless your rows are like 10 feet apart biggrin.gif
post #7645 of 8252
I am using T8's. I have similar width issues. The side surrounds will be almost on top of the outside seats. I will likely have them near the ceiling placed horizontally and angled down 45 degrees to keep the outside seats in the 90 degree dispersion. I need to keep the 4 front seats reasonable, since I don't always get my own seat when we have people over.
post #7646 of 8252
You should be fine. My surrounds are a slanted8 version I built out with the emminence10 instead, and a different compression driver. They aren't quite angled at 45 degrees but I wish they were, and mounted right below the 8' ceiling. Nevertheless, they spread over most of both rows quite well, and the cabinets for the sides are a total, height and width, 5 1/2-6 1/2 feet from the MLP
post #7647 of 8252
Horizontal T8's should make excellent surrounds and that 45º down angle will be perfect IMO. You can expect a lot of boundary gain from that placement. Audyssey often sets my Slanted 8 height and surround backs at 50hz due to the wall/ceiling corner placement. I bump them up to 100hz.
post #7648 of 8252
That is good to hear. In my old setup, Audyssey set my kit rear surrounds to 120 hz, despite a reported F3 of 40 hz. This could have been a problem with the speakers themselves, the placement, (The rear mounted passive radiators may have been too close to the wall), or a room mode. I have much better room treatment in my current space and hope to be able to set all 7 speakers to an 80 hz crossover. Now I need to decide whether to put my rear surrounds flat on the rear wall or mount them at 90 degrees (upright in the corners) for maximum coverage. I think I am leaning towards corner placement to take advantage of the 90 degree dispersion.
post #7649 of 8252
RMK,
Another question. I think you said you drilled into, but not through your Slanted 8's to use the speaker mounts, did you do something similar when using French cleats with your old T8's? If I am mounting my speakers at 45 degrees, I am thinking that I should actually drill through the backs, use bolts and put a nut on the inside of the speaker, or make a custom shelf with a lip. I am assuming that the French cleat method puts perpendicular forces on the screw, where there would be a very real risk of my screws being pulled out if I don't go through the plywood. In the back, I can just use a nice shelf.
This is all dependent on my wife letting me have the speakers visible. If not I will put them in boxes with grill cloth hiding them.
post #7650 of 8252
RMK,
Not sure what look you re going for but I have my 4 T8s enclosed ...just a point of reference for what they might look like.
  Back to Forum: Speakers
