building first htpc. want something compact yet versatile.
uses:
bluray video playback
hdmi output
dual display output
wifi
ps3 media server
media storage
ssd expandability (so I can isolate the OS from the media in the future)
and will be used as a 2nd computer with vista or linux and then windows 7 when it comes out.
Here is what I am thinking about:
ZOTAC GF9300-D-E LGA 775 NVIDIA GeForce 9300 HDMI WiFi Mini ITX Intel Motherboard
Intel Pentium E6300 Wolfdale 2.8GHz 2MB L2 Cache LGA 775 65W Dual-Core Processor
SILVERSTONE NT07-775 90mm CPU Cooler - Retail
DDR2 4GB PC6400 PNY
SILVERSTONE Black Aluminum / Steel LC09B Mini-ITX Media Center / HTPC Case
Seagate Barracuda 7200.11 ST31500341AS 1.5TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
Total PRICE: $455.96
OR
Intel Pentium E5200 Wolfdale 2.5GHz 2MB L2 Cache LGA 775 65W Dual-Core Processor
GELID Solutions Slim Silence 775 75mm Ball CPU Cooler - Retail
DDR2 4GB PC6400 PNY
M350 Universal Mini-ITX enclosure
TOTAL PRICE: $359.99
and I will be adding as many fans as/if I can.
I will be adding a bluetooth/ir remote and bluetooth keyboard and a blueray burner to the silverstone case(which means I would probably get the older version to have the larger drive space). ill also probably mount the m350 case onto a tv if i choose that one.
Now I'm also not really sure about what kind of power supply I need. any suggestions?
In addition I need to think of a workaround for this mobo since it does not support wake on usb. any thoughts?
Finally, I have also considered getting the ZOTAC IONITX-A-U Atom N330 1.6GHz Dual-Core 441 NVIDIA ION Mini ITX Motherboard/CPU Combo, but wanted to stray from it because of the inadequate flash output.
thanks for any ideas about the above. this is my end of summer project so I want to make it sweet.
mike
uses:
hdmi output
dual display output
wifi
ps3 media server
media storage
DDR2 4GB PC6400 PNY
OR
DDR2 4GB PC6400 PNY
mike
