Hello!
I recently bought the 2007/2008 Vizio XVT series 120 Hz 47 inch display and am using it as my monitor for my PC. When playing matroska files on my PC with this display @ 120 Hz, it looks great every few seconds or so and then starts to judder/lag/stutter. This cycle repeats itself with the picture looking fluid, then lagging, fluid, then lagging. I fiddled with all my TV/PC settings and had researched the solution to this issue, but I have no luck thus far. The only setting that helps 120 Hz playback with less juddering turning on deinterlacing to "Blend" mode using VLC player. Other than that, is there a solution to this issue? And if so, what can I do to fix it?
Any feedback would be greatly appreciated. Thank you!
PC Specifications:
Q6600 @ 3.60 GHz
4 GB PC2-6400 RAM
XFX NVIDIA 9800 GTX
750W Coolermaster PSU
XFX 680i SLI Motherboard
PC Specifications:
Q6600 @ 3.60 GHz
4 GB PC2-6400 RAM
XFX NVIDIA 9800 GTX
