I would first like to thank all members, particularly contributing members, for their input to this forum. I have been a member for many years and have gotten much information on many topics from review of this forum without the need to post.
I can add that I have scoured the net and this forum for the subject of this post and did not come away with the information I am looking for. If I missed it apologies in advance and can you please direct me to it.
The purpose of this post is ideally to get some insight from others with far more expertise and experience than I in this venue. I have been out of the loop for quite some time with respect to HT PJ's (see setup info below) and although I have done my homework on what is currently available I feel I lack the overall expertise to narrow the decision as to which PJ would fit my room layout best (see below for details). I am pleased with my current setup and due to my system's age I could use a complete overhaul (mostly audio for HDMI switching) and am very curious if others experience of upgrading from this era PJ to what the market currently offers has been a jaw dropping experience.
Current setup is a NEC LT240, 16x9, 96 dia. screen, 1.4 gain with component to VGA connection. Use is 100% HD material, 50/50 tv-sports/movies. Room is dedicated 11' x 12', white ceiling, walls and sofa (I know). 100% light control, ceiling mount only option, projector horz. centered on screen, vert. CL of lens 7.75" from ceiling, ceiling height 7.75', max distance from lens to screen 11' 2", seating eye approx. 10' from screen, 11.5" from ceiling to top of screen material.
This post is purposly targeted to this forum as I feel there are plenty of PJ's in this street price range that would work for me. I am not confused as to the available technology (lcd vs dlp) and am aware of the pro's and con's of each, except to the extent that others have had a much better experiance with either tech. based on the conditions I have to work with (throw distance, brightness, lens shift etc.). Nor do I have a feel for how far either tech. has come based on current opinions and reviews. Without trying to start a display type war this video adds to my confusion in the current market.
This is the best unbiased comparison I could find but I also realize it is potentially obsolete due to it's age (approx. 1 year). I have gone to dealers to look at PJ's but am truley intrested in unbiased end users opinions based on experiance with similar setups, issues and overall enjoyment away from the sales pressure and ideal/terrible setups of the showroom floor.
I am hopeful that you will share your experiances with me so that I might better understand that an upgrade from my current setup, will with PJ's currently available will blow me away and perhaps gain a consensous from those who have similar room layouts of which PJ has worked best.
Some addition info on my current setup. I am overall pleased with my setup but even watching in a totally darkened room it just doesn't seem bright enough more so on darker scenes, I suspect this has more to due with contrast then lumen output. This is where I need the most help in determing if an upgrade would even be worthwhile based on my room parameters. By spec the projector seems to have a bright enough output but I am not sure how much I am losing based on the 4:3 to 16:9 conversion. I have the projector set on economy, normal is brighter but not enough to offset the additional fan noise. For those familiar with this PJ I use the presentation mode as the other modes, although I can notice the warmth in color, just seems too dark (muddy?) in all programming to make it viewable. In order to fill the screen I have the PJ slightly tilted, virtually full wide angle (?), set to 5% overscan and have a fair amount of keystone (approx. 30% of limits ?) applied.
Sorry for such a long post just want to try and provide enough info to generate some responses and thanks in advance for any replies.
