I believe there maybe 2 fans inside the HD20,and I am assuming the following:-
First switch on the colour wheel spins straight away, not really audible.
Then you hear the lamp strike
Then the exhaust fan starts and after a short while I think the another fan starts both at Bright Mode level
then after another short while the fans drop to their normal eco mode speed.
Its that sequence I would just like to hear.
If I can here the lamp strike I can use that as a reference, assuming that the recording device does not have AVC.
Re Dave
Re Dave
