Originally Posted by xenon2000
wow, that does not look good. That is certainly not an optics issue or a DMD issue. Most certainly a bulb issue. Is that the bulb it came with? Did you buy the projector new or refurb? I wonder if some finger oils got on the bulb during install and it has begun to cook those oils. I am pretty sure a bulb replacement will solve this issue. But I would at least remove the bulb housing to see if you can see anything. Though it doesn't take much to see it on the screen, but it might not be so easy to see outside of the projector.
You should also check the front lens element as well. Also, has it always looked this way since you owned it? Or was it working fine and then this happened. My guess is that it has looked this way since the bulb was changed by someone.
Well, I took it in for another service 10 days ago, got it back yesterday, checked it today
Service notes
"replaced bulb"
"inspected. passed"
guess what.
yellow blob is still there in middle of screen
Manager will either be calling the police to have me escorted out or giving me a new projector on the spot
