Originally Posted by
lostsole1976
March 2011 Update: member jalfonso says in addition to what I have put below:
"my 5 cents. I had the same flickering problem described frequently with this projector. I followed the instructions to dissasemble. When taking off the cover start from the front of the pj. There is a snap in the central part but can easily be pulled off. There where no dust bunnies inside. Apparently Optoma has put some foam filters on the air entrance and the projector was almost clean."
More March 2011 updates: Also, it has now been a month and a half and my projector is still working like new since the cleaning. As a reminder the cleaning solved the following problems:
1. Blotchiness/pixelation in the dark skin tones or shadows. (This was initially before things got really bad)
2. Crazy purple and green flashing after having the projector on for just a few minutes. This rendered the picture un-watchable.
3. Strange ghosting and double images.
Some folks later after I initially posted this were not having the success I did. They may have a different problem OR, it could be that blowing out the unit with a high powered shop compressor did more to "clean it" and make it work right than I thought? I know some people would not have a high powered air compressor, thus they may substitute a can of compressed air. It is possible that this would not be strong enough to clear "something" that needs cleared? I just don't know?
If you decide to follow this procedure, please make sure you understand the following statements first.
1. I am not any sort of engineer, I could be doing something mechanically wrong to my projector and not know it. UPDATE (Actually, I broke one of my cover clips, so, see what I mean! However, I think you can do it without breaking it, thus learning from my pain.)
2. Doing this will certainly void your warranty, standard or extended.
3. Understand that I don't know if this is a long term fix? My projector is working great so far and it has been several days. There may indeed be other problems with the projector when it exhibits the symptoms earlier described, only time will tell? I really hate paying people hundreds of dollars for something I could have done myself in twenty minutes. I hope this is the big fix!?
4. Agree that you will not abuse me in any way if you do damage your projector. This includes eggs on my home, late night phone calls with heavy breathing, sending viruses, etc.
Special note: I had a hard time with the wire going form the control panel to the main board the 2nd time I took apart the projector. The blue plug in tab did not want to stay very easily, too loose. So, I had to have the cover down very close to the projector to create slack to get the plug to stay in. As I said in the tutorial, test the projector once you plug in the blue tab by plugging in the power cord first to make sure the tab is connected all the way when the cover is almost in place. See the photo below and take note as this is one thing that changed for me and was of some concern.
Special note 2: I realized I did not do a good job covering how the snaps seem to operate. I'm covering the back snaps as they seemed to give me all the trouble. So, I have gone back and looked more closely at what I did to separate the cover. I see I broke my right snap. No biggie, it still closes up.
Either way, the right snap above the power source input has a clip with a lip on it that hangs down from the cover and towards the front of the projector. This clips to the connector on the bottom projector main body near the power source. See photo below. Thus, I can imagine if one were to do this correctly, you would pull the cover back towards you to get this one snap to come undone.
Then, there is a recessed clip in the middle that hangs down from the cover and has a lip that faces BACK towards you. This may just come undone easily after the other snap, but, if not, one could likely poke the knife gently on it and push it back to release it. See photo UPDATE for the back of the projector.
I would love to hear any feedback or further info that one of you may learn that I missed?
Good luck and I hope this has been helpful. I did it because I wished very much someone had done it before me!
And yes, I know I spelled butter wrong.
[IMG]
Uploaded with
ImageShack.us
[IMG]
Uploaded with
ImageShack.us
[IMG]
Uploaded with
ImageShack.us
Uploaded with
ImageShack.us
Uploaded with
ImageShack.us
Uploaded with
ImageShack.us
[IMG]
Uploaded with
ImageShack.us
Uploaded with
ImageShack.us
Uploaded with
ImageShack.us
Uploaded with
ImageShack.us
Uploaded with
ImageShack.us
Uploaded with
ImageShack.us
Uploaded with
ImageShack.us
Uploaded with
ImageShack.us
Uploaded with
ImageShack.us
Uploaded with
ImageShack.us
