AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › *Official* Optoma HD20 Thread
*Official* Optoma HD20 Thread - Page 4
post #91 of 3801
big question
coming from 720p to 1080p. did you notice a great difference. distinguishable..??
thanks
thinking of selling my hc1500 to upgrade to this...
post #92 of 3801
As I understand it, the BC settings are baked into firmware. It's always on and you can't adjust it. So no mention of it in the menus.
Apparently this is a design "feature" because of it's positioning as entry level so as not to confuse users.
post #93 of 3801
Originally Posted by ditch-digger View Post
big question
thanks
YES!!! Way more detail.....way more.
post #94 of 3801
I don't like Brilliant Color. On my DT-500 all it seems to do is crush white detail for the illusion of a little more ansi contrast and brightness, but I see right through this crappy feature.
post #95 of 3801
From what distance?
post #96 of 3801
thanks
ebay here i come....
post #97 of 3801
Just to clear things up Deez you have an HD20 right? Not the HD200x.
Just for future post would be great if we can keep this topic to the HD20 as some of us are looking for that one and not the HD200x. Just keeps unnecessary confusion out of the thread.
post #98 of 3801
Originally Posted by MTyson View Post
From what distance?
12 1/2 feet away at 106"....might give or take 12 inches.
post #99 of 3801
HD20. And I agree that hd200x should have thier own thread.
post #100 of 3801
thanks
What are you going to ebay for?? To buy or sell? You can get this unit from Visual Apex and they are a reputable online dealer.
post #101 of 3801
Probably selling old projector, it's amazing what used projectors go for on the bay compared to what these new 1080ps cost considering they come with new bulbs, makes it tempting to upgrade every 6 months.
post #102 of 3801
lol i craigslist it make more no fees. Sold my HD-65 with 2100 hours on it for $575 now ordering HD20
post #103 of 3801
Recommended screens? How about Wilsonart fashion grey? Or perhaps some sort of paint?
post #104 of 3801
Just finished watching the BD "Crouching tiger ,hidden dragon". I can say that now having seen it in the dark it does leak light...not as much as mu old hd65 but some. Also, I do think black level can be improved without engaging AI. I will wait until some other people get thiers and do more advanced calibrations and see what happens. I feel very good about this projector though.
post #105 of 3801
deez, thanks for the screenies. Can you please verify if you have the BC option in your menus? TIA.
post #106 of 3801
going to sell the hc1500
post #107 of 3801
Wow I think this is exactly what I have bee waiting for. Now to find a grand. I don't know if there will be enough change in my ashtray and in the sofa cushions. Here's to hoping LOL.
post #108 of 3801
Well, FWIW, I decided to pull the trigger. Those screen shots in the ProjectorPeople review tipped the scales. I have a dark theater, and I am confident I can do a decent calibration.
Also - just my experience, but I had an excellent customer service experience with Optoma. The lamp on my HD73 burned out - they sent the wrong lamp as a replacement, but then sent me an entire new unit (!) to make up for it. A lot more than I was expecting. Anybody wanna buy an HD73 that only has a few months use?
post #109 of 3801
I have roughly adjusted it and by no means am I a pro like some guys here are on doing a comprehensive adjustment to this unit. I will also say i think it has plent of sharpness...as I was ably to make test pattern bleed on DVE and with the 65 and 70 I couldnt.
Oh, BTW, it is quieter than the hd65 was and it is 8 inches closer to my head.
Here's a tip on how to adjust the grayscale with the RGB/gains and bias.
With your HD-DVE disc display the brightness pluge pattern. Use the RGB gain to take color bias out of the lighter gray boxes, use the RGB bias to take the color out of the darker boxes. The tones should all look steely gray - no pinks or greens or bluish tones. When the graystep boxes all look gray your colors should look more natural.
Before you start you might toggle through the color temp choices while looking at the brightness gray steps. Find the one that has the least color bias, then use the RGB advanced gain/bias.
post #110 of 3801
Originally Posted by balagee View Post
The measuerments are 1400:1 on/off, and ~600 lumens at 6500k and low lamp mode.
(measured with light meter)
Palyed with HD20 more...... using other settings I was able to jump the On/off contrast to 1850:1 (in bright mode) with 6500k and low lamp mode. It makes about 650 lumens here. hte colors are not so goot but very close what i was able to get from the cinema mode.
So I say it's possibble to get 1850:1, and D65k with OK colors (far from perferct, but ok)
post #111 of 3801
I already did...there is no BC or true vivid in the menus.
post #112 of 3801
Thanks Tom...I look forward to hearing your review as well.
post #113 of 3801
I just read this online... Hopefully this applies for the HD20 since it has that mini usb input.
http://www.electricpig.co.uk/2009/06...-plans-for-3d/
"Excitingly, Optoma revealed that 3D-Ready versions of all its projectors may be coming along in the near future. For existing models, all that's needed is a firmware update."
Ordered mine yesterday should be here early next week.
post #114 of 3801
I am really anxious to get a 1080p projector. I've been waiting on this one, but I don't think I can wait any longer. I need to buy from Best Buy and they just dropped the PLV-1080HD to 1399. Not discussed a ton around here, any ideas if it's worth an extra 3 bills?
post #115 of 3801
Hi, i have a question. I just got my DVE disc and i was testing it out on my lcd screen and when going through the menu it only looks like i can start certain chapters and it forces me to fast forward to the test pattern. Is there a menu that lets you pick test patterns? Or maybe I'm just over looking it.
post #116 of 3801
Whoops! My bad! Missed that post among all the screen shots...sorry about that...
post #117 of 3801
According to the reviews on Amazon, this is the only difference between the DVD and Blu-Ray version of DVE. if you want better menus, get the Blu-Ray. Since I already have the DVD, it doesn't seem worth it just for that feature.
post #118 of 3801
Actually it is there, i just over looked it. I was able to access the menus i wanted
take a look here on how to do it.
http://www.ramelectronics.net/Video-calibration.ep
post #119 of 3801
Originally Posted by jsm88 View Post
Optoma HD200x is NOT the HD20.
I don't think anyone (that does not work for Optoma) can declare this a certainty until both units are tested side by side.
Afterall, would it really make sense for Optoma to produce 2 different so similarly specced machines, particularly at their price points?
post #120 of 3801
I'm of the same mind as you on this one. It doesn't make sense that they would build two units so similar in every way. Looking at the HD20 unboxing photos Deez posted, everything was identical to what I received with my HD200x.
I'm heading stateside next week so if I can pick up an HD20 for $999 US while I'm there I will return my HD200x that I got for $1499 CAD; if so this will give me the chance to compare them side by side.
