AVS › AVS Forum › Display Devices › CRT Projectors › Powerstrip settings for BARCO 1209s - 1080p
post #1 of 7
Hey!
I use a HTPC with powerstrip to view 1080p on my BARCO 1209s.
What are the best setting of powerstrip for 1080p?
I use 1920 x 1080 @ 72 Hz (picture below) but sometimes I have problems with the stability.
Sometimes the BARCO goes to bank 4, but there the bank is empty.
I think it could be a problem with powerstrip...
Thanks for help!
post #2 of 7
Search out the VESA GTF spreadsheet. (This should have been a sticky 10 years ago, but I've never seen this mentioned anywhere on AVS.)
post #3 of 7
Add more back porch pixels, it sounds like you are on the border of two memory blocks in the barco.
Get it a bit further away from 80khz.
post #4 of 7
@ Mark_A_W: thank you for your advice! Now I have modified my powerstrip setting to 79,914 kHz. Is that right?
I will try this the next days...
post #5 of 7
It works for few weeks, but now I have the same problem again!!!!
My powerstrip setting is still at 79,914 kHz.
But my BARCO select always a empty memory bank...
Has anybody a idea?
Pleas help me...
post #6 of 7
I would try to chance vertical sync to negative.
Also 71.928 Hz vertical refresh rate could give smoother pans.
post #7 of 7
Yes, that is a coincidence.
Is that 79.914 Khz scanrate? Or 79.914hz vertical refresh rate?
  Back to Forum: CRT Projectors
