Just wanted to say that after a lot of research I decided to say "screw the numbers" and bought the 42UT50.
Honestly...I'm happy with the purchase. Not only the picture quality is great, everything I could do on my old Pana LCD (which supposedly has 1 frame of lag) I can do on this TV, no adjustment needed. I play fighting games, which are heavily affected by lag, and I can pull off my combos just fine, UMvC3, Tekken 6, KOF XIII, whatever.
Bottomline: yes I recommend this TV for gaming. But if you can test it beforehand, please do so. JUST DON'T PLAY WITH IFC TURNED ON or you're gonna be in lag hell (game mode disables IFC by default anyway).
UNFORTUNATELY...plasma TVs simply were not made for 30 fps games. I was playing Final Fantasy XIII and had to switch to non-game mode and put IFC on maximum because I find the ghosting in 30 fps games to be unbearable. When you pan the camera around EVERYTHING gets a double image, it's just awful, so consider yourself warned. Games like FF XIII are not affected by input lag so I could play it just fine with IFC turned on.
And finally...I read somewhere that the same TV models may have different input lag depending on the region. So it's possible that the american model has more lag than the european model. I'm in Brazil, and our model, based on the menu options, is the european one.
Good luck to you guys.
