AVS › AVS Forum › Audio › Speakers › Need help connecting Z-2300 to Vizio
post #1 of 11
I apologize first off if I am posting this is the wrong place or if this has been answered before. I've spent the past 3 hours looking for the answer to this on this forum and others and haven't found my answer.
So, I have a Sony Vizio LCD HDTV. I have the Logitech Z-2300 speakers with the headphone style output. I lost the adapter that came with the speakers that connect the pale green output to an all female-Y cable.
I need a cable that will connect this single speaker cable to my HDTV audio out. I suppose I need a 1Female/2Male Y Cable, but I bought one from radio shack and it doesn't work.
What cable do I need?
I think my cable connector needs to look something like this one (except mine would need two red/white male ends)
http://i32.tinypic.com/dqnjir.jpg
Thanks for the help!
post #2 of 11
No ideas?
post #3 of 11
You need a 3.5mm female connector to RCA Red and White male connector. You will then connect the RCA Red and White male to the TV's Red White female audio out connection.
post #4 of 11
post #5 of 11
This is the wrong one. He needs the Headphone end to be a female end and not a male end.
This is the one he needs. http://www.mycablemart.com/store/car...t_detail&p=602
post #6 of 11
Third to last picture shows exactly what is needed.
post #7 of 11
Yes, but the option above your post means he won't need an extra RCA cable and can plug the adapter directly into the TV.
post #8 of 11
The Logitech takes a 1/8" male for audio signal input. The pale green he referred to in the OP is a standard for computer connections - it refers to a 1/8" male stereo plug - the one thats been mis-placed. I have the same pale green male stereo 1/8" plug on a JBL Creature I use in the shop for connecting a Sony Walkman to for radio and playing tapes. For that I use a double ended male 1/8" stereo adapter. It plugs into the pale green port on the JBL Creature.
Maybe this would work?
post #9 of 11
This is the one he needs. http://www.mycablemart.com/store/cart.php?m=product_detail&p=602
What you linked above has a female RCA on one end.
He needs a female mini-jack there, so maybe this one:
http://www.techcables.com/6-inch-3-5...able-p-42.html
post #10 of 11
From the OP:
Perhaps you missed that. If he still had that little connector your solution would work. If he gets the double male 1/8" stereo adapter your suggestion would work
post #11 of 11
Now I could have sworn I updated that link. I think when I did an edit, I accidentally pasted the wrong link again. oops.
But yes, the one you linked to was the one I meant to link to.
I will edit mine again, this time correctly.
Ok It works now.
  Back to Forum: Speakers
