AVS › AVS Forum › Audio › Surround Music Formats › SACD & DVD-A Test Discs?
post #1 of 8
Any thoughts on where I might find test tone discs in SACD and DVD-A? I'd like to make some objective comparisons of the output of all the channels.
post #2 of 8
What sort of test tones?
post #3 of 8
Slow frequency sweeps, pinknoise, perhaps a series of sine waves, every third of an octave.
The reason for this is I'm having a difficult time wrapping my brain around base management with DSD vs PCM. I could create my own Redbook CD disc if I needed to, using software. But I have no means of authoring a SACD or DVD-A.
I'd also like a good way to compare the output of these formats over analog Multichannel connections vs HDMI.
post #4 of 8
pink noise is easy as it is found on the original Sony/dmp SACD sampler, Telarc's 1812 (SACD and DVD-A) and on the Chesky Ultimate DVD-A (http://www.chesky.com/core/details.c...221&category=1). The latter has more test signals but neither is a full-bore test disc.
Why are you having a difficult time?
post #5 of 8
Thanks for the info.
As to your question, I think it's a case of teaching an old dog new tricks. All the issues get my head swimming. LFE needs a 10db boost, provided by the amp. Some music sources have the bass 10db down, some don't. HTMI connections get bass management at the receiver (Onkyo TX-SR805) analog connections don't.
I'm using two disc players. I had hoped to be using just one, the new Oppo BDP 83, but with its fan coming on to keep it cool, I'm thinking of just using it for movies, and keeping the Oppo 980 for music. The players have some bass management capabilities built in. I could use different connections for different types of discs, if that's what I need to do to get optimal frequency response from each source.
But it's just hard to keep it all sorted out in my head. ;-)
post #6 of 8
I have those 2 and run them both via HDMI. No conflicts in bass management that way.
post #7 of 8
...and on the Chesky Ultimate DVD-A (http://www.chesky.com/core/details.c...221&category=1). The latter has more test signals but neither is a full-bore test disc.
The Chesky DVD/DVD-A surround disc gets my vote as the overall best *surround sound* test disk that I've got. As well as that the DVD-A part has a small bit of truly excellent 5.1 music.
Since I'm not in the biz, I'll reference amazon: http://www.amazon.com/Ultimate-Surro...8887261&sr=8-4
Ignore the owner reviews, as this is a 5 star disc. IMO of course.
Cheers
post #8 of 8
I love the Chesky disc as well. I use the imaging tests to set my delay times with excellent results. (better than using a tape measure) I use those tests for my delay times in my oppo 83 and switch to bitstream and use the same patterns to adjust my delay time in my AVR.
I do like the bass management tests and channel levels as well. There is a test for each 10 hz step but i don't remember where it starts at.
  Back to Forum: Surround Music Formats
