Originally Posted by Francois Caron
Second, the info on the HF21 is now available. The only significant difference I could find aside from the built-in memory is the OIS, which is called SuperRange Optical Image Stabilization on the HF200, and Dynamic SuperRange Optical Image Stabilization on the HF21.
I see that the built-in memory is now doubled as compared to the HF20, 64gb as opposed to 32gb. If it sells for the same street price as the HF20, it might be a worthwhile upgrade to the HF200 because now the price difference narrows considerably with card purchases in mind. Four cheap 16gb cards are half the $300 price difference between the HF20 and the HF200....
Not to mention the cooler paint job.
Then again, does this mean that we can look forward to an HF210? The super-duper image stabilizer probably isn't going to be enough of an upgrade for them to release a new model. I'm guessing that Canon figured out what the consumers already figured out, that the giant price difference between the 20 and the 200 was hard to justify when you realize how many memory cards you can buy for those hundreds of dollars.
